Software freeware per GIS
PlannerRoad
Staff Forum
Professione: Variabile
Software: AutoCAD 2019
Regione: Italia
#21
SHAPE CHECKER
"Number of shapes does not match number of table records"? Look familiar?
As long as your .shp is in order, this program will re-generate your .shx which is the shapefile index (not the spatial index). Also, if you have too many or too few records in the dbf, it will add or delete records to match the shapefile. Thus, you can completely fix this problem automatically..
If your dbf file is completely missing, then this will generate a new one with unique ids so that at least you can keep your spatial data.
At the moment, it will also recover shapes up to the point of premature file end. It also now handles premature end (before data begins) in the dBase file as well giving the option to delete and recreate."
http://www.geocities.com/SiliconValley/haven/2295/howto_shapechk.html
PlannerRoad
Staff Forum
Regione: Italia
#25
listgeo_GUI (GeoTIFF Tools)
Consente di estrarre worldfile/metadati da un file GeoTiff e di incorporare i worldfile/metadati in un file tiff.
http://freegeographytools.com/2007/another-tiff-worldfilemetadata-program
Download:
ftp://ftp.remotesensing.org/geotiff/libgeotiff/listgeo_GUI.zip
Questo programma (sempre dello stesso autore) è una evoluzione del precedente:
libgeoGUI
http://freegeographytools.com/2007/a-new-gui-for-the-libgeotiff-worldfile-utilities
Download:
http://freegeographytools.com/upfiles/libgeoGUI.zip
Ultima modifica:
PlannerRoad
Staff Forum
Regione: Italia
#27
GeoSetter
Leggere qui.
http://www.geosetter.de/en/index.html
GEOTAGGER
http://craig.stanton.net.nz/software/Geotagger.html
GRAZER
Leggere qui.
http://www.grazer.de/
PhotoMapper
Leggere qui.
http://copiks.com/software/photomapper/
LOCR
Leggere qui.
http://www.locr.com/
GPicSync
Leggere qui.
http://code.google.com/p/gpicsync/
Ultima modifica:
PlannerRoad
Staff Forum
Regione: Italia
#30
QUIKGRID
Importa punti 3d e consente di creare una rappresentazione della superficie del terreno tridimensionale assegnando delle colorazioni alle differenze di quota. Consente l'esportazione in dxf. Leggi anche qui: Link.
http://www.perspectiveedge.com/
SurGE
SurGe is a computer program which enables to generate a surface as an interpolation (approximation) function of two independent variables.
http://www.geocities.com/miroslavdressler/surgemain.htm
SURFIT
Surfit is a computer program which enables to calculate regular grid from various data (scattered points, 2D and 3D contours, surfaces, etc) in different ways (interpolation, approximation, inequalities, etc). Surfit implements the original gridding method.
http://surfit.sourceforge.net/
3DField
3DField s a contouring surface plotting and 3D data program that runs under Microsoft Windows 95/98/2000/XP. 3DField converts your data into contour maps and surface plots. All aspects of 2D or 3D maps can be customized to produce exactly the presentation you want.
http://3dfmaps.com/
Ultima modifica:
PlannerRoad
Staff Forum
Regione: Italia
#33
GPS TrackMaker
Il software consente un interscambio di dati tra un GPS e Google Earth.
Infatti, importa dati da un GPS; esporta tali dati in Google Earth e importa file kml che possono poi essere a sua volta trasformati e importati nel GPS.
Leggere anche qui: Link1 e Link2
http://gpstm.com/
Ultima modifica:
PlannerRoad
Staff Forum
Regione: Italia
#34
FWTools
E' un kit open source di applicazioni per il GIS
E’ composto dai seguenti pacchetti:
OpenEV: A high performance raster/vector desktop data viewer and analysis tool.
MapServer: A web mapping package.
GDAL/OGR: A library and set of commandline utility applications for reading and writing a variety of geospatial raster (GDAL) and vector (OGR) formats.
PROJ.4: A cartographic projections library with commandline utilities.
OGDI: a multi-format raster and vector reading techology noteworthy for inclusion of support for various military formats including VPF (ie. VMAP, VITD), RPF (ie. CADRG, CIB), and ADRG.
Python: a scripting language.
http://fwtools.maptools.org/
Ecco solo alcuni esempi di cosa può fare questo kit:
- Ricavare le metainformazioni disponibili in un file GeoTiff
- Estrarre le metainformazioni da un file vettoriale
- Convertire in batch da tif, ecw e jpg2000 a tif, ecw e jpg2000
PlannerRoad
Staff Forum
Regione: Italia
#38
Dxf2PostGIS
Uno strumento per convertire i file DXF in tabelle geometriche di PostGIS. Ciascun file DXF viene convertito in uno script SQL per PostgreSQL/PostGIS che crea e popola 5 tabelle, usando le informazioni AutoCAD di point, line, polyline, text, circle, insert.
http://www.glasic.it/dxf2postgis.html
acadmap2pgsql
The program is an intersection of Autodesk Map to the PostgreSQL/PostGIS database management system. The function of the program is to convert all geometrical information and the combined object data into SQL-commands and to issue a pgsql-dump.
http://sourceforge.net/projects/acadmap2pgsql
