sistemazione listato per selezione multipla
jim78b
Professione: PROGETTISTA
Software: Solidworks 2016- autocad mech 2013-2017
Regione: lombardia
ho questo listato per cambiare il colore ai blocchi nidificati mi servirebbe fare che si possa selezionare più di un oggetto grazie e perfavore...
(defun c:blcc () (pl:block-color) (princ))
(defun c:encc () (pl:block-ent-color) (princ))
;;;get from Alaspher http://forum.dwg.ru/showthread.php?t=1036
;;; http://forum.dwg.ru/showpost.php?p=166220&postcount=18
(vl-load-com)
(defun pl:block-ent-color (/ adoc blocks color ent lays)
(setq adoc (vla-get-activedocument (vlax-get-acad-object))
lays (vla-get-layers adoc)
color (acad_colordlg 256)
(if color
(progn (setvar "errno" 0)
(vla-startundomark adoc)
(while (and (not (vl-catch-all-error-p
(setq ent (vl-catch-all-apply
(function nentsel)
'("\nSelect entity <Exit>:")
(/= 52 (getvar "errno"))
(if ent
(progn (setq ent (vlax-ename->vla-object (car ent))
lay (vla-item lays (vla-get-layer ent))
(if (= (vla-get-lock lay) :vlax-true)
(progn (setq layloc (cons lay layloc))
(vla-put-lock lay :vlax-false)
(vl-catch-all-apply (function vla-put-color) (list ent color))
(vla-regen adoc acallviewports)
(princ "\nNothing selection! Try again.")
(foreach i layloc (vla-put-lock i :vlax-true))
(vla-endundomark adoc)
(princ)
(defun pl:block-color (/ adoc blocks color ins lays)
blocks (vla-get-blocks adoc)
(if color
(setq ins (vl-catch-all-apply
(function entsel)
'("\nSelect block <Exit>:")
(if ins
(progn (setq ins (vlax-ename->vla-object (car ins)))
(if (= (vla-get-objectname ins) "AcDbBlockReference")
(if (vlax-property-available-p ins 'path)
(princ "\nThis is external reference! Try pick other.")
(progn (_pl:block-color blocks ins color lays)
(princ "\nThis isn't block! Try pick other.")
(princ)
(defun _pl:block-color (blocks ins color lays / lay layfrz layloc)
(vlax-for e (vla-item blocks (vla-get-name ins))
(setq lay (vla-item lays (vla-get-layer e)))
(if (= (vla-get-freeze lay) :vlax-true)
(progn (setq layfrz (cons lay layfrz)) (vla-put-freeze lay :vlax-false))
(progn (setq layloc (cons lay layloc)) (vla-put-lock lay :vlax-false))
(vl-catch-all-apply (function vla-put-color) (list e color))
(if (and (= (vla-get-objectname e) "AcDbBlockReference")
(not (vlax-property-available-p e 'path))
(_pl:block-color blocks e color lays)
(foreach i layfrz (vla-put-freeze i :vlax-true))
(progn
(princ "\BLCC - Changes color of the chosen blocks")
(princ "\nENCC - Changes color of the chosen objects (may be element of the block)")
(princ))
jim78b
Regione: lombardia
poi avrei anche questo che ruota e copia 1 sola volta mi servirebbe che copia infinite volte sino a che interrompo io il comando è possibile? grazie
(defun C:RTC (/ gru)
(setq gru (ssget))
(if gru
(progn
(command "_COPY" gru "" (list 0 0)(list 0 0))
(command "_ROTATE" "_P" "")
(princ "\nBase point e primo punto d'angolo: ")
(command pause "_R")
(command (getvar "LASTPOINT"))
(princ "\nSecondo punto d'angolo: ")
(command pause)
(princ "\nAngolo finale: ")
(command pause)
(princ)
Cristallo
Professione: Leggo e confronto
Software: Lettura critica
Regione: Fuori dalla cerchia
(defun C:RTC (/ gru break)
(setq break nil)
(while (=/ break nil)
(setq gru (ssget))
(if gru
(progn
(command pause)
(command pause)
(princ)
jim78b
Regione: lombardia
Grazie mille.e x il primo lisp?
jim78b
Regione: lombardia
scusami Cristallo non funziona dice:
Command: rtc ; error: no function definition: =/
Command:
rpor66
Professione: Programmatore
Software: AutoCad, CadWorx, Lisp, VBA. YouTube: roberto portuese
Regione: Sicilia
cambialo in /=
jim78b
Regione: lombardia
abbi pazienza ma mi esce ora:
Command: rtc nil
rpor66
Regione: Sicilia
Codice:
    (setq break T)
    (while (/= break nil)
        (prompt "\nSeleziona entità: ")
        (setq gru (ssget))
        (if gru
            (progn
                (command pause)
                (command pause)
        (princ)
(setq break T)
jim78b
Regione: lombardia
Grazie ora provo :).riesci x favore a sistemare l'altro listato x selezionare piu' oggetti ?te ne sono grato
jim78b
Regione: lombardia
Ho Provato RTC.LSP ma non è come dico, vorrei fare come il comando copia, che ripete gli oggetti fino a che non interrompo il comando.
