i can't open any file cimatrone e12 at windows 10...
shirokko
Professione: Progettista cad-cam
Software: CimatronIT, Cimatron 13, Rhinoceros 5, Solidworks 2019, SolidCAM 2018
Regione: Marche
#2
Can you retrieve any message when you try?
Zahid
Utente registrato
Professione: engineer
Software: cimatrone12
Regione: Bangladesh
#3
No , there is no massage. just loading icon come and then no response.
shirokko
Regione: Marche
#4
I use come e 12 in win 10 without troubles. What happens of you launch Cimatron from start menu?
Zahid
Utente registrato
Regione: Bangladesh
#5
i use 64 bit at 64 bit of win 10...
starting is okay. no problem. but when i want to open a file it don't work....?
shirokko
Regione: Marche
#7
If you're inside CimatronE and you try to work clicking on "File">"Open" or "File">"New File", and the cad crashes opening the graphic window, maybe you have a trouble with the graphic card or the video driver.
Using CimE 12 in Windows 10 has some small issues, but generally it works.
Zahid
Utente registrato
Regione: Bangladesh
#8
I am using Nvidia graphics.
What are using for video and graphics driver....?
shirokko
Regione: Marche
#9
Nvidia Is usually ok, but your PC may to be checked.
Zahid
Utente registrato
Regione: Bangladesh
#10
my Nvdia version is 32 bit ... Is the problem is with that ???
64 bit necessary???
