Estrudere nome file in un ipt
Ivantecnico
Professione: Tecnico
Software: Inventor 2019
Buon giorno a tutti, vorrei sapere se esiste un metodo che mi permetta di importare in uno schizzo di un ipt il nome del file. O il suo "numero parte".
Allegati
Cast16
Professione: Design Engineer
Software: Inventor, Autocad, Solid Edge
Regione: UK
Non credo direttamente ma con un Ilogic rule.
Dai un'occhiata al file allegato.( E' possibile che non si possa allegare un file ipt in questo forum?!)
Allora crea questo rule:
AddReference "System.Web"
Imports System.Web
Sub Main()
doc = ThisDoc.Document
SketchText = iProperties.Value("Project", "Part Number")
Dim strings as New Generic.List(Of String)
strings.Add(SketchText) 'string parameter holding text I want to push to the sketch
SetSketchText("PN Text", strings)
iLogicVb.UpdateWhenDone = True
End Sub
Private doc as Document
Public Sub SetSketchText(ByVal sketchName As String, ByVal strings As Generic.List(Of String))
Dim Sketch As PlanarSketch = FindSketch(sketchName)
For Each textB As TextBox In Sketch.TextBoxes
' Diagnostics.Trace.WriteLine("-- Formatted Text = " & textB.FormattedText)
Dim newFormattedText As String = ReplacementFormattedText(textB.FormattedText, strings)
textB.FormattedText = newFormattedText
Return
Next
End Sub
Public Function ReplacementFormattedText(ByVal formattedText As String, ByVal strings As Generic.List(Of String)) As String
Dim textLength As Integer = formattedText.Length
Dim k_gt As Integer = formattedText.IndexOf(">"c)
If (textLength < 4 OrElse k_gt < 0) Then
Return strings(0) ' no formatting
End If
Dim newFormattedText As String = String.Empty
Dim stringsIndex As Integer = 0
Dim k_start As Integer = 0
Do
k_gt = formattedText.IndexOf(">"c, k_start)
If (k_gt > 0) Then
newFormattedText += formattedText.Substring(k_start, k_gt - k_start + 1)
Dim k_lt As Integer = formattedText.IndexOf("<"c, k_gt + 1)
If (k_lt > k_gt + 1) Then
If (stringsIndex < strings.Count) Then
newFormattedText += HttpUtility.HtmlEncode(strings(stringsIndex))
stringsIndex += 1
End If
End If
k_start = k_lt
End If
Loop Until k_gt < 0 OrElse k_start < 0
Return newFormattedText
End Function
Public Function FindSketch(ByVal sketchName As String) As Inventor.PlanarSketch
Dim sketches As Inventor.PlanarSketches = Nothing
Dim oPartDoc As Inventor.PartDocument
Dim oAssemDoc As Inventor.AssemblyDocument
If (doc.DocumentType = Inventor.DocumentTypeEnum.kPartDocumentObject) Then
oPartDoc = doc
sketches = oPartDoc.ComponentDefinition.Sketches
ElseIf (doc.DocumentType = Inventor.DocumentTypeEnum.kAssemblyDocumentObject) Then
oAssemDoc = doc
sketches = oAssemDoc.ComponentDefinition.Sketches
End If
If (sketches Is Nothing) Then Return Nothing
For Each Sketch As Inventor.PlanarSketch In sketches
If (String.Compare(Sketch.Name, sketchName, True) = 0) Then
Return Sketch
End If
Next
Throw New ArgumentException("No sketch named: " & sketchName & " was found.")
End Function
E dai un'occhiata al video.
Se cambi il PN e salvi il file, il testo cambia.
