altre abbreviazioni nelle note (E - H)
painaz
Professione: ingegnere
Software: proe
Regione: veneto
E
EO, ECO, ECN engineering order An order from the engineering department (to be followed by the production department or vendor) overriding/superseding a detail on the drawing, which gets superseded with revised information. Also called by various other names, such as engineering change order (ECO), engineering change notice (ECN), drawing change notice (DCN), and so on. See also REV.
EQ equal, equally For example, "⌀10 4X EQ SPACED ON BC" means "drill four holes of 10mm diameter equally spaced around the bolt circle."
F
f finish An italic f (Latin small letter f) written on a line representing a surface was an old way of indicating that the surface was to be machined rather than left in the as-cast or as-forged state. The "f" came from "finish" in the sense of "machine finish" as opposed to raw stock/casting/forging. Later the ASA convened upon a letter V (specifically a sans-serif V) touching the surface. Soon this evolved into the "check mark" sign with accompanying number that tells the reader a max roughness value (RMS, microinches or micrometres) for the machined finish, to be measured with a profilometer.
FAO finish all over A note telling the manufacturer that all surfaces of the part are to be machined (as opposed to leaving any surfaces as-cast or as-forged). Not an obsolete usage, but not seen as commonly as it was decades ago; not least because parts that once would have been spot-faced castings are now likelier to be contoured from billet with CNC milling. But more importantly, best engineering practice today, reflecting design for manufacturability and avoidance of spurious cost drivers, is either to specify specific, quantifiable requirements for surfaces with specific needs (such as RMS roughness measurements in microinches or micrometres, plus any plating or painting needs), or to leave finish out of the part definition (and thus at the manufacturer's discretion) because it is not important to fit, function, or criticality. This same spirit is behind the shift in military standards from writing requirements about methods to writing them instead about performance, with the method to reach that goal being up to the ingenuity of the designer.
FCF feature control frame The rectangular box (with several cells) that conveys geometric tolerances in GD&T. It typically tells you what sort of geometric condition (e.g., parallel, perpendicular, round, concentric), followed by what size (and maybe shape) the tolerance zone is, and finally which datums it relates to, the order of gaging against them, and what material condition applies to them (LMC, MMC, or RFS). A diameter symbol (⌀) tells you that the zone for the geometric tolerance is cylindrical.
FD or F/D field of the drawing The [main] field of the drawing, as opposed to other areas of it, such as the parts list (P/L), general notes (G/N), flagnotes (F/N or FL), title block (T/B), rev block (R/B), bill of materials (B/M or BoM or BOM), or list of materials (L/M). Rationales for drawing changes that are noted in the rev block often use these abbreviations for brevity (e.g., "DIM 14.00 was 12.50; added default TOL info to T/B; added leader lines to F/D; added alternate hardware IDs to P/L; added alternate alloy to L/M").
FIM full indicator movement See also TIR.
FL flag note, flagnote A note that is called out in specific spots in the field of the drawing. It is numbered with a stylized flag symbol surrounding the number. A general note applies generally and is not called out with flags.
FN or F/N flag note, flagnote; find number 1. Flagnote: A flagnote is a note that is called out in specific spots in the field of the drawing. It is numbered with a stylized flag symbol surrounding the number (or sometimes a delta symbol). A general note applies generally and is not called out with flags. 2. Find number: "FN" meaning "find number" refers to the ordinal number that gives an ID tag to one of the constituents in a parts list (list of materials, bill of materials). Thus "fasten using FN7" refers to a fastener that is "find number" 7 in the list.
FoS feature of size A type of physical feature on a part. An FoS is a feature that can have size associated with it, usually involving the opposition of two surfaces (e.g., the two diametrically opposite sides of a hole wall; the two opposite walls of a slot or flange). Features of size (FoSs) in reality always have actual sizes and forms that differ from their theoretical size and form; the purpose of tolerancing is to define whether the difference is acceptable or not. Thus material condition (LMC, MMC, somewhere in between, or RFS) is important in GD&T. ) A given geometric tolerance may be defined in relation to a certain FoS datum being at LMC or at MMC.
FS far side The drawing notations "near side" and "far side" tell the reader which side of the part a feature is on, in occasional contexts where that fact is not communicated using the rules of projection alone. Contexts of usage are rather limited. One example is hole locations; "3X AND 3X FAR SIDE" defines symmetrical groups of 3 holes on both sides of a part (6 total), without having to redefine equivalent hole center coordinates on two separate views, one for each group. This is not only a convenience for the designer but also a method of error prevention, because it provides a way to avoid forking geometric definition that ideally should be kept unforked to prevent discrepancies. For example, the groups defined above cannot accidentally become asymmetrically discrepant in a future revision by the revisor failing to revise both groups equally (because their definition is unified in only one place). Another example is part marking locations. An area for part identification marking can be circled on a top view but assigned to either the top or bottom of the part simply with a "near side" or "far side" notation—which obviates adding any otherwise-unneeded bottom view to the field of the drawing.
FSCM Federal Stock/Supply Code for Manufacturers An older name for "CAGE code". Also NSCM (National Stock/Supply Code for Manufacturers).
G
GCI gray cast iron
GD&T or GDT geometric dimensioning and tolerancing A standardized language for defining and communicating dimensions and tolerances.
GN or G/N general note(s) Most engineering drawings have a notes list, which includes both general notes and flag notes.
H
HBW hardness, Brinell, tungsten tip See Brinell scale. (The "W" comes from the element symbol for tungsten, W, which comes from the German Wolfram.)
HHCS hex head cap screw
HRA hardness, Rockwell, A scale See Rockwell scale.
HRB hardness, Rockwell, B scale See Rockwell scale.
HRC hardness, Rockwell, C scale See Rockwell scale.
HRS hot rolled steel
HT TR heat treat, heat treatment
H&T or H/T or HT hardened and tempered A form of heat treatment in which the metal is first hardened and then tempered. Compare N&T.
