Errori di scrittura durante l'installazione di Inv.10
amangano
Professione: impiegato
Software: inventor
Regione: sicilia
Salve a tutti,
Utilizzo Inventor Prof. series 10
Ho cambiato pc e installato win service pack3.
Non riesco a completare l'installazione senza errori , mi dice: Errore 1406, impossibile scrivere il valore nella chiave \Software\casses\CLSID\......
se dico ignora, mi ripete poi un'altro errore con lo stesso codice e altri numeri
Riesco comunque a completare l'installazione, ma poi vedo che il programma e lentissimo a caricare,
Qualcuno sa dirmi qualcosa?
Forse Windows è "troppo aggiornato" per Inv. 10?
VigZ
Professione: -
Software: Catia V5 -Inventor simulation 2012
Regione: piemonte/lombardia
#2
KNOWLEDGE BASE DI INV...
http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=7201635&linkID=9242018
Published date: 2006-May-01
Applies to:
Autodesk Inventor® 11
Autodesk Inventor® 10
Issue
When you tried to install Autodesk Inventor®, the installation stopped and you received the following error message:
1406-Could not write value to key
Solution
This error is due to insufficient permissions and/or a security conflict with a registry subkey. This error will occur even if the user has full rights to the registry and/or administrative privileges.
To resolve this issue, you need to give full control to the registry key that contains the applicable registry subkey for the active user account and the local system account. Follow these steps:
1. In the 1406 Error window, note the specific location of the registry subkey.
2. Exit the installation.
3. On the Start menu (Windows), click Run.
4. In the Run dialog box, enter regedit. Click OK.
5. In the Registry Editor, browse to the registry subkey that was displayed in the 1406 Error window.
6. Right-click on the registry key that contains the registry subkey. Click Permissions.
7. In the Permissions dialog box, Click Advanced.
8. In the Advanced Security Settings dialog box, locate the following user accounts:
• The current login account. For example, “Joe User (joe.user@mycompany.com).”
• The local system account. For example, “SYSTEM.”
9. Select the current login account. Click Edit.
10. In the Permission Entry dialog box, click Clear All.
11. Under Permissions, select the Allow check box for Full Control. Click OK.
12. In the Advanced Security Settings dialog box, select the local system account. Click Edit.
13. In the Permission Entry dialog box, click Clear All.
14. Under Permissions, select the Allow check box for Full Control.
15. Click OK to close each dialog box.
16. Close the Registry Editor.
You should now be able to install Inventor.
Note: You may experience multiple 1406 errors during the installation. You will need to repeat this procedure for each registry subkey that produces a 1406 error.
Warning! Problems caused by improperly editing the Windows registry could render your computer operating system unusable. Microsoft provides a wealth of critical information that you need to know about the registry in the Microsoft Knowledge Base at http://support.microsoft.com.
Use the Microsoft® Registry Editor only at your own risk and only after backing up the registry as well as the system.dat and user.dat files as outlined for your operating system in the Microsoft Knowledge Base. Additional information about the registry is also contained in the Help topics in the Microsoft Registry Editor.
stefanobruno
Staff Forum
Professione: Progettazione caotica e notturna e Seguace Anonimo di Shiren :)
Software: Inventor 2016 - Autocad ( read only ) - Rhino un pochino
Regione: Piemonte,Torino
#3
Salve a tutti,
E' una situazione nota che non pregiudica l' installazione.
E' la prima volta che lo installi su questa macchina ?
Su che macchina ?
Lentissimo quanto ?
amangano
Software: inventor
Regione: sicilia
#4
Si è la prima volta.
Il pc è un assemblato AMD Dual core 5600+ (2,9 Ghz) su M.B. ASUS M3N78-EM
Disco 320 Gb, Memoria DDR2 800 2 Gb
Scheda video SAPPHIRE ATI PCI-E-HD4450 DDR3 512MB (AMD/ATI)
Per caricare impiega circa 2 minuti contro 55 secondi del mio pentium centrino mobile da 2 Ghz "vecchio di 4 anni).
stefanobruno
Staff Forum
#5
Mi ritiro, ha risposto molto meglio VigZ, fai come dice lui.
( ATI no bbuono !! 50 euri di scheda ? )
VigZ
Professione: -
#6
BISOGNEREBBE VEDERLO per capire che fare... che processi girano su, antivirus e altro...
pagnotz
Professione: Progettista
Software: Autodesk Inventor Simulation Suite 2010
Regione: Abruzzo
#7
Il problema non è dovuto alle caratteristiche hardware del tuo computer, si presenta per un conflitto con la versione 8a di Flash Player, leggi qui:
http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=7118892&linkID=9242018
Qua spiega come fare per "ripulire" il sistema dalla 8a dopo aver disinstallato Inventor, dopodichè vai ad installare dal sito di Adobe l'ultima versione (adesso c'è la 10), infine reinstalli Inventor.
Se hai altre domande o problemi con l'inglese, fai sapere :smile:
amangano
Software: inventor
Regione: sicilia
#8
E' giusto, ho disinstallato flash Player (ma avevo la versione 10) riavviato e installato Inventor senza problemi. Poi ho riinstallato Flash Player 10 è tutto adesso funziona a meraviglia.
Grazie tantissmo
Angelo
pagnotz
Regione: Abruzzo
#9
Purtroppo me lo ricordo ancora bene quel problema... Tutti quei messaggi di errore che non finivano mai! :eek:
