Comandi e Variabili non documentati
PlannerRoad
Staff Forum
Professione: Variabile
Software: AutoCAD 2019
Regione: Italia
#23
Comando non documentato per la rigenerazione in modalità 3d di Autocad 2008.
"The standard REGEN command doesn't work in AutoCAD 3D display modes (Shademode) - visual styles are regenerated automatically as needed. If, for any reason, you need to invoke a regen of a 3D view manually, use the undocumented AutoCAD 2008 command REGEN3."
http://www.cadforum.cz/cadforum_en/qaID.asp?tip=5480
PlannerRoad
Staff Forum
Regione: Italia
#24
Opzione non documentata per Autocad 2004/2005/2006/2007 per alcuni comandi 3d.
"Some AutoCAD 3D editing commands (e.g. FILLET) support an undocumented option RESFIT (resolution fit).
Try to answer the prompt "Select an edge or [Chain/Radius]:" with the keyword RESFIT. AutoCAD then uses the value of internal resolution from its 3D modelling kernel ACIS/Shapemanager. Works in AutoCAD 2007, 2006, 2005, 2004."
http://www.cadforum.cz/cadforum_en/qaID.asp?tip=4965
PlannerRoad
Staff Forum
Regione: Italia
#25
Non documentati comandi per Autocad 2006 e 2007.
AutoCAD version 2006 (and higher) contains two undocumented commands which update the attribute extraction tables (EATTEXT).
The EATTEXTEDIT command allows to edit the definition of the extracted table (manual attribute edit, adding new attributes). Select the extracted table before starting this command.
The EATTEXTUPDATE command invokes update of the extracted table, e.g. after changes performed in attributes of the drawing blocks. This command is equivalent to the the Update function in the table context menu. Select the table before starting this command.
http://www.cadforum.cz/cadforum_en/qaID.asp?tip=5377
PlannerRoad
Staff Forum
Regione: Italia
#26
Consente, tramite una finestra di dialogo, di eliminare i filtri layer. Funziona dalla versione 2006 in poi.
PlannerRoad
Staff Forum
Regione: Italia
#27
Non documentati comandi per Autocad 2008.
Hanno rispettivamente la funzione di aggiungere e rimuovere le multidirettrici.
"The commands with a little strange names AIMLEADEREDITADD and AIMLEADEREDITREMOVE are only slight modifications of the standard multileader editor - MLEADEREDIT. These undocumented commands are by default set to simplify adding and removing leader arrows in multileaders."
http://www.cadforum.cz/cadforum_en/qaID.asp?tip=5955
PlannerRoad
Staff Forum
Regione: Italia
#29
Variabile di sola lettura, che indica il numero dei cambiamenti (modifiche al database degli oggetti del disegno) che avvengono in un dwg.
(Segnalata da GP.)
PlannerRoad
Staff Forum
Regione: Italia
#30
Variabile non documentata per Autocad 2009.
Consente di utilizzare la nuova o vecchia finestra dei layer. Di default è impostata a 1. Dandole il valore 0 la nuova finestra dei layer utilizzata in Autocad 2009 verrà sostituita da quella delle versioni precedenti.
PlannerRoad
Staff Forum
Regione: Italia
#31
Comandi non documentati per Autocad 2009 per l'apertura della finestra nuova/vecchia dei layer.
CLASSICLAYER comando che consente di aprire la vecchia finestra di dialogo dei layer, invece di quella nuova di default di Autocad 2009.
LAYERPALETTE comando alternativo a LAYER, consente di aprire la finestra nuova dei layer, quando la variabile LAYERDLGMODE è settata a 0.
http://www.cadforum.cz/cadforum_en/qaID.asp?tip=6378
Ultima modifica:
GP.
Professione: Nientologo
Software: uozapp
Regione: Vercelli
#33
M2P e MTP (sono equivalenti) consentono di selezionare un punto medio tra due punti.
Ad esempio dovendo selezionare il centro di un rettangolo basta selezionare i due vertici della diagonale (senza disegnarla).
Da 2005.
PlannerRoad
Staff Forum
Regione: Italia
#34
Per il comando LAYERFIN esiste una opzione non documentata _reMoverriders che è l'equivalente di "Rimuovi modifiche locali finestra per tutti i layer" che appare con il tasto destro quando si clicca su una finestra.
L'abbreviazione invece è _M
PlannerRoad
Staff Forum
Regione: Italia
#35
E' possibile accedere alla Knowledge Autodesk con questi comandi non documentati (testato sulla 2010 e 2011, non so su versioni precedenti):
AI_PRODUCT_SUPPORT e AI_PRODUCT_SUPPORT_SAFE: svolgono la stessa funzione e indirizzano alla pagina AutoCAD Services & Support:
http://www.autodesk.com/autocad-support
se LT invece:
http://www.autodesk.com/autocadlt-support
AI_CUSTOM_SAFE: indirizza alla pagina Autodesk Services & Support Developer Center: http://www.autodesk.com/developautocad.
AI_TRAINING_SAFE: indirizza alla pagina AutoCAD Services & Support Training: http://www.autodesk.com/autocad-training
(in AutoCAD LT va alla pagina training relativa all'LT).
AI_SEND_FEEDBACK: indirizza alla pagina di contatto Autodesk:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
Fonte
Joseph
Professione: studio e sperimento
Software: autocad 2012
Regione: lombardia
#36
Splits a filename into path, filename base and extension:
(fnsplitl "C:\\ACAD2000\\Drawing1.dwg")
Esempio:
("C:\\ACAD2000\\" "Drawing1" ".dwg")
Joseph
Regione: lombardia
#37
;Checks if a number exceeds the upper range of real numbers
(vl-infp num)
Examples
(vl-infp 1.79769313486e308)
nil
(vl-infp 1.79769313487e308)
T
To track the amount of time spent in each drawing. The first integer of the
dotted pair that it returns appears to be the number of milliseconds that
the app has been running. The second integer is constant within each
drawing; maybe a handle to the dwg.
(_vl-times)
Joseph
Regione: lombardia
#38
(_VL-BALANCE-PARENTHESIS) turns on/off the feature that makes the cursor jump for a split second to the opening parenthesis when typing a closing ditto. This has no effect on the parenthesis matching commands in Edit or the alert about suggesting to match paren's when formatting code. T=on, nil=off.
(_vl-balance-parenthesis nil) => turns off parenthesis flashing
(_vl-balance-parenthesis T) => turns on parenthesis flashing
(_vl-balance-parenthesis 100000)
(_vl-balance-parenthesis T 100000) => turns on parenthesis flashing with delay
(_vl-balance-parenthesis 1 100000) => turns on parenthesis flashing with delay with highlight
