Centroide di un'area delimitata da una polilinea
Professione: *
Software: AutoCAD
Inserisce un punto nel centroide delle geometrie selezionate (le polilinee devono essere chiuse)
Codice:
(defun c:polycen (/ polySet polyList Model newPl obArr newReg newPt)
  (princ "\n*** Select closed polylines *** ")
  (if
  (setq polySet(ssget '((0 . "LWPOLYLINE"))))
   (progn
     (setq polyList(mapcar 'vlax-ename->vla-object
                            (vl-remove-if 'listp
                              (mapcar 'cadr(ssnamex polySet))))
      Model(vla-get-ModelSpace
         (vla-get-ActiveDocument
           (vlax-get-acad-object)))
      ); end setq
     (foreach p polyList
       (if(= :vlax-true(vla-get-Closed p))
    (progn
       (setq newPl(vla-copy p)
        obArr(vlax-make-safearray vlax-vbObject '(0 . 0))
        ); end setq
       (vlax-safearray-put-element obArr 0 newPl)
       (setq newReg(car(vlax-safearray->list
           (vlax-variant-value
             (vla-AddRegion Model obArr))))
             newPt(vlax-3d-point
          (append
            (vlax-variant-value
         (vla-get-Centroid newReg)))(list 0.0)))
    ); end setq
       (vla-AddPoint Model newPt)
       (vla-delete newPl)(vla-delete newReg)
       ); end progn
    ); end if
       ); end foreach
     ); end progn
  (princ "\n*** Notning closed polylines selected! *** ")
  ); end if
  (princ)
  ); end of c:polycen
(vl-load-com)
segnalato da antoniovinci
Ultima modifica:
