AutoCAD Map 3D - Manuali, Tutorials, Tips & Tricks
PlannerRoad
Staff Forum
Professione: Variabile
Software: AutoCAD 2016
Regione: Italia
#2
Ultima modifica:
PlannerRoad
Staff Forum
Regione: Italia
#3
Connessione a Server WMS
http://map3d.blogspot.com/2006/10/co...erver-wms.html
__________________________________________________
Usare dati WMS
http://www.cadforum.cz/cadforum_en/qaID.asp?tip=5063
Creare un nuovo schema SDF
http://map3d.wordpress.com/2007/11/18/create-a-new-sdf-schema/
Importare un file CSV
http://map3d.wordpress.com/2008/01/02/bring-a-csv-file-into-map-3d-with-data/
Usare MySQL con FDO in AutoCAD Map 3D 2008
http://cadngis.blogspot.com/2008/01/using-mysql-with-fdo-in-autocad-map-3d.html
Dati geospaziali in un file DWF
http://thecadgeek.com/blog/2007/04/19/geospatial-data-in-a-dwf-file/
Ultima modifica:
PlannerRoad
Staff Forum
Regione: Italia
#5
Ultima modifica:
PlannerRoad
Staff Forum
Regione: Italia
#6
With the Map's MAPCLEAN command, you can easily change all your drawing lines, arcs, circles and 3D polylines to classic polylines or circles to arcs.
Select the objects (or use All), from the cleanup options select one of 'safe' methods - e.g. Delete duplicates (with any parameters) and in the last step choose in the "Convert selected objects" field the requested conversion - e.g. "Circle to polyline" plus "Arc to polyline". Start the cleanup - the command performs the conversion on the selected objects (even if they do not qualify for the cleanup method). The number of converted objects is listed.
http://www.cadforum.cz/cadforum_en/qaID.asp?tip=5506
PlannerRoad
Staff Forum
Regione: Italia
#7
Per inserire un immagine georeferenziata in Map 3D non bisogna utilizzare la classica procedura di Autocad.
Il procedimento è quello di utilizzare il comando MAPIINSERT, oppure attraverso il menù:
Map -> Immagine -> Inserisci
PlannerRoad
Staff Forum
Regione: Italia
#8
Convertire il sistema di coordinate di un disegno
http://thecadgeek.com/blog/2008/01/11/converting-a-drawings-coordinate-system/
Trasformazione sistemi di coordinate
http://map3d.blogspot.com/2009/02/trasformazione-sistemi-di-coordinate.html
Mappe catastali: trasformazione sistemi di coordinate Cassini Soldner in UTM o Gauss Boaga
http://map3d.blogspot.com/2009/03/mappe-catastali-e-cassini-soldner.html
Ultima modifica:
PlannerRoad
Staff Forum
Regione: Italia
#11
Autodesk organizza periodicamente delle sessioni di formazione in modalità Webcast, dove è possbile seguire in diretta e comodamente dal proprio PC le lezioni tenute da esperti.
Alcune delle sessioni tenute vengono registrate e rese disponibili per una consultazione in differita che è possibile seguire quando si è più comodi.
Queste sono quelle relative al Gis, tra cui, oltre ad altri software Gis Autodesk, sono presenti due webcast relativi a Map 3D:
http://www.autodesk.it/adsk/servlet/item?siteID=457036&id=9868411#section4
PlannerRoad
Staff Forum
Regione: Italia
#13
Pagina della Autodesk che contiene la documentazione relativa a Map 3D. Interessante il file GIS Skills for Engineers che è un tutorial che mostra l'utilizzo del programma anche attraverso 75 animazioni che rendono più facile e veloce l'apprendimento, consentendo di scoprire facilmente le potenzialità del software.
"The GIS Skills for Engineers book is intended to help people with engineering and drafting experience learn how to perform GIS tasks using Map 3D. With over 75 “show me” animations, this book makes GIS easy to learn; it helps you quickly get up to speed on how to get the most out of the GIS features in Map. The GIS skills are data-oriented examples concerned with tasks such as data preparation and cleanup, data management and data sharing. Many of the skills are also feature-oriented, dealing with real-world objects such as roads and parcels rather than geometric entities such as polylines and polygons."
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=8447905
GimmiGIs
Professione: Architetto GIS
Software: AutoCAD Map 3D
Regione: Italia
#14
Prova a premere il bottone DATI nel riquadro attività, poi scegli il provider per le immagini raster...
Carica anche i DEM!
Buon lavoro
GimmiGIS
gcedizioni
Professione: editore, autore, grafico, docente
Software: AutoCAD, AutoCAD Map 3D, 3D Studio, Photoshop e Revit
Regione: Sardegna
#16
E' finalmente disponibile il libro AutoCAD Map 3D 2010&2011 Cartografia dal CAD al GIS. Per maggiori informazioni visitate il sito www.gcedizioni.it dove è possibile scaricare un intero capitolo correlato da file per gli esercizi e video-esercizi. Saluti Gabriele Congiu
gcedizioni
Regione: Sardegna
#17
