Risultati da 11 a 17 di 17
    Utente Standard L'avatar di lelepanz
    367
    Ingegnere
    aclt-sw2010
    Risolto con l'SP3 di SolidWorks 2009.
    Scusa Alessandro,
    per me c'è ancora qualcosa di anomalo su quel comando.
    Un angolo se ne infischia bellamente... e mi devo tenere 4 pezzi di 4 misure diverse se coglio evitare l'accorcio del secondo comando.
    Potresti controllare?
    1159
    Progettazione meccanica
    NX3;NX6 e SW2009
    Citazione Originariamente Scritto da lelepanz Visualizza Messaggio
    Scusa Alessandro,
    Hai ragione.
    Questo è quello che la SW ha dedotto:
    Alessandro,
    I was just speaking with development about your weldment corner treatment issue and we've come to the conclusion that there are two separate defects.
    1. Is the SPR I previously created for you, SPR 483558. I have re-named this SPR to identify a more specific problem. The new name of the SPR is, " Structural member, End Butt1 corner treatment is incorrect when sketch entities are selected clockwise as one group with no protrusion".
    2. SPR 485684 - Allow protrusion option is not available in corner treatment pop up window for multi-grouped weldments
    You are experiencing both of these problems. The original part that you sent me (L0T.1511.SLDPRT) exhibit the problem documented in SPR 483558 when you disable allow protrusion for the structural member.
    The newest part that you sent me (Rexroth problem SP3.SLDPRT) exhibits this SPR as well. The problem with it is that the corner treatments are not consistent. All the corner treatments in the structural member need to be the same, but two of them are End Butt2 treatments. If you correct this, you will see the problem in SPR 483558. You must enable allow protrusion for the structural member and use cut-extrudes to achieve your desired results.
    Non credo che lo risolvano per l'SP4, a meno che ci siano molte richieste di risoluzione.
    Attualmente sono l'unico che ha segnalato questo.
    Se tu e gli altri partecipanti al forum con l'SP3 installato, segnalano questa anomalia, allora forse si smuoverà qualcosa, altrimenti forse nell'SP5 o nella 2010.
    Vedete voi, io a parte segnalarlo, non ho nessun peso sulla risoluzione.
    Alessandro
    367
    Ingegnere
    aclt-sw2010
    Hai ragione.
    Alessandro,
    Ciao, come dovrei fare a segnalarlo senza passare dall'assistenza?
    C'è qualche modo? Io per ora gli unici 2 buggozzi li ho segnalati all'assistenza e tramite loro hanno aperto un SPR.
    1159
    NX3;NX6 e SW2009
    SEMPRE tramite il tuo VAR.
    Io ho avuto risposta perché con l'SP3.0EV, testandolo e vedendo questa nuova opzione, ho notato che non lavorava a dovere.
    Per questo mi hanno ascoltato, altrimenti mi avrebbero detto di sentire il mio VAR.
    Tra i bug che hai segnalato, vi è anche questo ?
    Ti hanno assegnato un SPR, se si corrisponde a uno di questi ?
    Se non corrisponde, vuol dire che tu l'hai segnalato, ma loro no.
    Oltre a me e a te, devi confidare nella buona volontà degli altri utenti del forum, che segnalino anche loro ai propri VAR il medesimo problema.
    Alessandro
    367
    Ingegnere
    aclt-sw2010
    Ciao Alessandro,
    ma il VAr è quello che io chiamo assistenza? :D
    Cmq, no, avevo segnalato all'assistenza ma non mi era stato assegnato nessun SPR.
    Al contrario di altri 2 SPR di cui mi hanno assegnato il numero, se vuoi poi li riporto.
    Ma come posso fare a segnalare lo stesso SPR, chiamo l'assistenza e dico, "ragazzi sono afflitto dal bug in questione...tal dei tali..già preso nel SPR...tal dei tali ?... :D
    1159
    NX3;NX6 e SW2009
    Ciao Alessandro,
    Si...il VAR è il tuo rivenditore di SolidWorks e chi ti fa assistenza telefonica.
    Anche a me non piace parlare con acronimi, ma ti evitano di scrivere a volte in Inglese e quindi possibilità di errori e poi le frasi sono più corte.
    Per quanto riguarda il problema, dici che hai installato l'SP3 e nelle nuove opzioni di taglio automatico durante la creazione del tuo elemento saldato, disabilitando l'opzione 'Permetti estensione' che dovrebbe tagliarti que naselli che compenetrano nel profilato di Rexroth, ottieni il risultato voluto ma non su tutti e comunque fa un casino perchè crea delle lungezze strane.
    Se ti dicono che deve funzionare così e di continuare ad usare il trim....non so casa dirti...probabilmente sono degli incompetenti.
    La segnalazione serve solo per aumentare gli 'hits' sul problema.
    Come riportato altre volte, la SW Corp. assegna delle priorità ai problemi e anche dei punteggi.
    E' chiaro e logico che se un'azienda con 100 postazioni segnala un problema, gli danno una priorità alta.
    Se il problema di cui stiamo parlando lo segnalano in 2...capisci anche te che peso avrà.
    Forza e coraggio....devi solo far capire al tuo VAR che esiste questo problema e di segnalarlo perchè tu lavori solo su profilati Rexroth e che le tue strutture sono molto grandi e se eviti il comando trim perchè già inglobato nella creazione dell'elemento strutturale, il file risulterebbe molto più leggero.
    A propostio, ti hanno assegnato il problema del mirror ?
    Inseriscilo anche qua, così lo tengo monitorato.
    Alessandro
  7. #17
    367
    Ingegnere
    aclt-sw2010
    SPR#474257 <- bug del mirror
    Poi avevo trovato anche un altro bug relativo al modulo saldature, cioè che nella distinta di taglio non taglia bene....:D
    praticamente ho fatto una mensola, composta da un profilo U100 tagliato a 45° ad entrambe le estermità.
    Se faccio un trim alla volta...nella distinta di taglio mi segnala il taglio giusto, se lo faccio insieme nella distinta di taglio invece mi segnala - - negli angoli di taglio.
    SPR 472377 -> SPR assegnato
    Thank you for contacting SolidWorks Technical Support. I could reproduce the problem of not calculating Angle weldment cut list property on my side also. Also I found that this is a regressed behavior from SolidWorks 2008. I have confirmed this problem and this has been submitted as a Problem Report to the SolidWorks Development team. The reference number for this issue is SPR 472377 (If weldment structural member trim/extended at both ends then angles are not calculated in cut list properties). I have submitted this issue with regression as severity and medium customer impact You will be notified when this issue has been resolved. Unfortunately, there is no workaround present for this case.
    Per il bug in oggetto invece ho aperto chiamata all'assistenza. :D
    1. Lamiera: unione facce con funzione di ripetizione
      Di PLOTTER83 nel forum Inventor
    2. creazioni propri manuali didattici in ambito CAx / PLM?
      Di falonef nel forum Modelli 3D e risorse varie dedicate ai progettisti meccanici
    3. La sicurezza del lavoro in ambito industriale
      Di gfrank nel forum Convegni, fiere e mostre
    4. Windows in ambito militare
      Di cacciatorino nel forum Software freeware di utilizzo generale
    5. solidworks in ambito architettonico
      Di hrodebert nel forum Solidworks
