Discussione: MP3 per STv100
    2874
    teorico del paleocontatto
    Veneto (PD)
    Predefinito MP3 per STv100
    no non è un file di musica
    Hanno rilasciato la Maintenance pack 3 per solid edge ST
    Legal Notices
    ©2009 Siemens Product Lifecycle Management Software Inc.
    All Rights Reserved
    Software, file formats, and audiovisual displays may be used pursuant to the
    applicable Software License Agreement and contain confidential and proprietary
    information of Siemens Product Lifecycle Management Software Inc.; which is
    protected by copyright and trade secret law. Such materials may not be reproduced
    or transferred to other documents or used or disclosed to others for manufacturing
    or for any other purpose except as specifically authorized within the terms of the
    Software License Agreement, or as specifically authorized in writing by Siemens
    5800 Granite Parkway
    Suite 600
    Plano, TX. 75024
    End of Legal Notices
    Release Notes:
    Product: Solid Edge
    Version: 100.00.03.03
    Date: 15-Jan-2009
    This Maintenance Pack can be installed on top of Version:
    100.00.00.133, 100.00.01.07, or 100.00.02.07.
    Note: Maintenance Packs are all inclusive and can be installed on top of the base
    release or any released Maintenance Pack.
    End of Release Notes
    Installation Notes:
    After downloading the Maintenance Pack to your machine, dbl click the downloaded
    file and the Maintenance Pack will install.
    End of Installation
    This Maintenance Pack addresses the following PRs:
    =====Assembly=====
    PR 1702197: Animation Editor Timeline crashes Solid Edge
    PR 1515114: Pattern of a family member is not created correctly in this assembly
    PR 1693966: Out of context tube still updates after a Save As of the assembly
    PR 2097365: Variable renamed by user in V19 is not being displayed with variable table filter
    PR 5918252: Pattern is not updating in this file when Height is set to original value
    PR 6018360: Solid Edge hangs when changing placement options while placing angular relationships
    PR 6061245: Column designer is calculating the wrong area moments of inertia for I-beams
    PR 6063339: Opening a sub-assembly and then IPA into Part shows the wrong tree in Pathfinder
    PR 6066064: Cannot locate pattern along curve reference feature
    PR 6073010: Reorder not working when in place activated
    PR 6075425: No Cancel or Finish buttons were displayed in assembly feature pattern CommandBar.
    PR 6075436: Smart/Fast pattern buttons moving around in CommandBar.
    =====Part/Profile/Sheetmetal=====
    PR 1701884: Solid Edge aborts when opening Advances Units in File Properties
    PR 2111593: Strange lines appear in this Draft file
    PR 6027495: Save As to ACIS is moving the version up 4 from the version selected
    PR 6075309: XpresRoute floating license not functioning properly
    PR 6012839: Simplify B-splines is not working in certain files
    PR 2113007: Solid Edge aborts when dismissing the default layer properties dialog
    =====Draft=====
    PR 1683725: Unable to drive the position of a text profile with dimensions
    PR 1698339: Solid Edge aborts when fit is performed in this Draft file
    PR 2070745: The display of the value of a "Chamfer Dimension" is shifted
    PR 2110529: "Dimension value" is lying on top of "Dimension line"
    PR 2111938: ACAD multiple text color is not imported
    PR 5938516: Weld Symbol Properties dialog missing General tab at times
    PR 6050476: Layer names are mistranslating
    PR 6064282: Angular dimensions are incorrect when saving to AutoCAD
    End
    Gianluca...alias Tequila
    546
    Ufficiale tecnico
    Solid Edge ST9
    Uhm...perchè io non la trovo nel solito sito?
    546
    Ufficiale tecnico
    Solid Edge ST9
    Ora c'è
    E hanno pure risolto un problema che avevo io.
    Ficco.
    952
    Romagna
    ciao, mi è arrivata la scatola x la ST!!
    sono dietro un progetto con la v20 e mi ci vorra' almeno un'altra settimana per finire il progetto,
    mi consigliate di installare la ST o date le differenze nel modo di lavorare, faccio prima con la v.20 ??
    so che la domanda è strana ma spero di raccogliere qualche opinione
    Gianluca
    546
    Ufficiale tecnico
    Solid Edge ST9
    Con la ST puoi lavorare anche nella maniera tradizionale.
    Tieni conto però che l'organizzazione dei comandi è molto diversa.
    Un paio di giorni ti ci voglioni di sicuro, forse anche di più.
    Con la MP3 è abbastanza stabile finalmente, almeno per quello che faccio io.
    Cmq se la consegna del progetto è urgente secondo me ti conviene aspettare.
    2874
    Veneto (PD)
    Citazione Originariamente Scritto da Leso Visualizza Messaggio
    concordo, usa la v20 e finisci quello che devi fare, con più calma installi la ST
    e cominci a giocherellarci...
    1. update solid edge STv100 mp11
      Di Tequila nel forum Solid Edge
    2. Solid EDGE STv100 informazioni utili
      Risposte: 20
