BuonGiorno a tutti sono alla disperata necessitÓ di dover utilizzare Probatch per stampare o Convertire Liste di Oggetti DRW in DWG o DXF...
Ho settato Distribuited Pro BATCH per la conversione e funziona
il giochino nn mi funziona con la stampa nn mi riesce a far stampare.
qualcuno ha qualche suggerimento?
eccovi il file ttd configurato:
<?xml version="1.0" encoding="UTF-8"?>
<!-- 18-Feb-02 J-03-19 TWH $$1 Submitted -->
<!-- 08-Apr-02 J-03-23 TWH $$2 delete_after = true -->
<!-- 16-Aug-02 J-03-32 MFL $$3 Added node <DETAILS>, Edited <DESCRIPTION> node -->
<!-- 04-Nov-02 J-03-37 TWH $$4 draw_format = true -->
<TTD version="1.0" created_by="PTC">
<DESCRIPTION>PLOT/PRINT DIRECTLY To PRINTER</DESCRIPTION>
<DETAILS>Create and send plot directly to printer/plotter specified, delete plot file after plot/print is complete</DETAILS>
<SERVICE name="dbatchs"/>
<TKFUNC func="ProPrintExecute">
<PCF_FILE></PCF_FILE>
<TKSTRUCT struct="ProPrintPrinterOpts">
<printer_type>POSTSCRIPT</printer_type>
<!-- Do not save to file -->
<save_to_file>false</save_to_file>
<save_method enum="PRINT_SAVE_SINGLE_FILE"/>
<delete_after>false</delete_after>
<!-- Send to printer -->
<send_to_printer>true</send_to_printer>
<!-- Set the appropriate print command -->
<print_command>print /D:\\nrisp02\Pl1 </print_command>
<pen_table>table.pnt</pen_table>
<paper_size enum="A4_SIZE_PLOT"/>
<quantity>1</quantity>
<sw_handshake>true</sw_handshake>
<roll_media>false</roll_media>
<cutter>false</cutter>
<slew>-1.000000</slew>
<rotate_plot>false</rotate_plot>
</TKSTRUCT>
<TKSTRUCT struct="ProPrintMdlOpts">
<quality>3</quality>
<use_solid_scale>false</use_solid_scale>
<use_drawing_size>false</use_drawing_size>
<draw_format>true</draw_format>
<segmented>false</segmented>
<layer_only>false</layer_only>
<layer_name></layer_name>
<sheets enum="PRINT_CURRENT_SHEET"/>
</TKSTRUCT>
<TKSTRUCT struct="ProPrintPlacementOpts">
<scale>1.000000</scale>
<offset x="0" y="0"/>
<keep_panzoom>true</keep_panzoom>
<clip_plot>false</clip_plot>
<shift_to_ll_corner>false</shift_to_ll_corner>
<clip_area idx0_0="0.000000" idx0_1="0.000000" idx1_0="1.000000" idx1_1="1.000000"/>
<place_label>false</place_label>
<label_height>0.000000</label_height>
</TKSTRUCT>
</TKFUNC>
</TTD>
