Risultati da 1 a 9 di 9
Discussione: SEV20 SP10
    9340
    Predefinito SEV20 SP10
    E' uscito il SP10 per V20:
    This Update addresses the following Customer Reported PRs:
    =====Assembly=====
    PR 5737340: Fixed a problem that caused a circular dependency error using FlashFit.
    PR 1649779: Fixed a problem where the DELETE key in assembly does not work at times.
    PR 2076104: Fixed a problem where in the user is unable to auto-restore a backed up file.
    PR 1628066: Fixed a problem with FOA and Assembly Features
    PR 2088091: Fixed a problem where it takes too much time and memory to update the "Physical Properties”
    PR 2085635: Fixed an abort from data submitted via a crashlog.
    PR 6022024: Fixed a problem with include that was introduced in Update 9.
    PR 1681255: Fixed a problem where Save As Image does not create a rendered image in Foundation
    PR 1586883: Fixed a problem where Part colors are not exported to step.
    PR 6023710: Fixed a problem where washers are not available with C'snk screw
    PR 6001319: Fixed a problem where embedded weldment information gets lost
    PR 6026967: Fixed a problem where previous custom part inherits length of the most recently placed part.
    PR 6033504: Fixed a problem where a revolved cutout is removing material where there is no sketch.
    PR 6000242: Fixed a problem where you are unable to import an STL file.
    =====Part=====
    PR 6006751: Fixed a problem where the Hole Table is not listing the correct hole diameters for a counterbore
    PR 1641087: Fixed a problem that was causing a crash with an old part in V20 SP3
    PR 1668197: Fixed a problem where DIN.PZL will not be used for lofted flanges
    PR 1680457: Fixed a problem where typing "=" and selecting dim adds multiple entries to variable table.
    PR 5782978: Fixed a problem where moving the cursor over Variable table causes zoom to happen or automatically
    PR 2105606: Fixed a problem where a Round disappears when part is recomputed in Version 20
    PR 2102531: Fixed a problem where creating an open profile protrusion on a tapered face failed in V20
    PR 2096263: Fixed a problem where you are unable to make a dimple that uses an inside edge.
    PR 1603406: Fixed a problem with mirror performance on grouped 2D elements, maintain relationships on
    PR 6040150: Fixed a problem with Tool Tips not displaying properly when using SmarTeam
    =====Draft=====
    PR 5992242: Fixed a problem where EMF's are scaled incorrectly
    PR 5941495: Fixed a problem where a specific workflow with Blocks will cause a draft file to be unusable.
    PR 5969985: Fixed an abort from data submitted via a crashlog.
    PR 2107915: Fixed a problem where data alignment in table properties is incorrect
    PR 6024647: Fixed a problem that caused Solid Edge to crash when copying a fill style
    PR 2105954: Fixed a problem where a Japanese font is not mapped to an ACAD font.
    PR 1684163: Fixed a problem where you cannot copy and paste a view that contains a coordinate dim
    PR 1535069: Fixed a problem where you are unable to hide an overridden edge segment
    PR 6031576: Fixed a problem where Solid Edge runs out of memory when working with shading Drawing views.
    PR 1644606: Fixed a problem where a drawing view is never up to date
    PR 1632537: Fixed a problem where you save a Solid Edge draft file as a pdf file and the output is rotated.
    PR 6020990: Fixed a problem where you cannot import a draft file
    =====API=====
    PR 5544696: Fixed a problem with Expose Parasolid id/tag via API for Body, Edge, Face, Loop, Shell and Vertex
    PR 1619947: Fixed a problem with a call to SurfaceBoundaries.Add failing with 'type mismatch'.
    =====Insight/=====
    PR 5549874: Fixed a problem where Parts are shown as Designed even though they are Simplified parts
    PR 6029411: Fixed a problem where Solid Edge crashed when IPA on a part or assembly from a checked out Draft file.
    End
    Moderatore L'avatar di gerod
    3875
    Libero professionista
    Mi hai anticipato.
    ma lavori anche oggi?????
    9340
    Mi hai anticipato.
    no, oggi tempo brutto e fidanzata al lavoro: se riesco studio salome....
    E' che stavo gironzolando su cad.de (carina la galleria di SolidEdge-Gallery of death) districandomi con il tedesco e ho visto l'annuncio...
    Ultima modifica di cacciatorino; 01-11-2008 alle 13: 05 Motivo: correzioni ortografiche
    100
    Disegnatore-progettista
    Emilia
    Inventor - Solid Edge
    potreste postare il link diretto del Download? grazie mille
    9340
    Citazione Originariamente Scritto da alex_novi Visualizza Messaggio
    Telefona al tuo rivenditore se sei in assistenza. Se invece l'assistenza non ce l'hai e' inutile darti il link perche' tanto non potresti scaricarlo ugualmente.
    100
    Emilia
    sono in assistenza... ho i codici e tutto! ma non lo trovo sul sito...
    poi lo cerco meglio!
    SE_CP
    Accedi all'area GTAC
    Inviare e ricevere
    Inserisci il tuo User e Password
    Selezioni Solid Edge alla voce Product Update
    Cartella Ver20
    Cartella Solidedge32
    Cartella Update10
    quindi scarichi il file .exe
    45
    Tecnico - Progettista
    Io l'ho installato e lo sto usando da un giorno, ha risolto egregiamente il problema dll'includi scaturito dalla relese 9.
    Ciao a tutti
    100
    Emilia
    Danke se_cp!
    1. SE ST1, disponbile SP10
    2. SEV20-SP15
    3. SEV20-SP13 SEST-MP5
    4. SEV20 SP11
    5. SEv20 grandi assiemi
      Di Tequila nel forum Solid Edge
