Risultati da 1 a 10 di 11
    Bannato
    1683
    AutoCAD
    Predefinito File manager alternativi a gestione risorse di Windows
    freeCommander
    http://www.freecommander.com/
    Dual-panel technology - horizontal and vertical
    Tabbed interface
    Optional tree view for each panel
    Built in file viewer to view files in hex, binary, text or image format
    File viewer inside archives too
    Built in archive handling: ZIP (read, write), CAB (read, write), RAR (read)
    Nested archive handling
    Easy access to system folders, control panel, desktop and start menu
    Copy, move, delete, rename files and folders
    Wipe files
    Create and verify MD5 checksums
    File splitting
    File properties and context menu
    Calculation of folder size
    Folder comparison / synchronization
    Modification of file date and attributes
    Folder / program favorites
    File searching (inside archive too)
    File filters for display
    User defined columns for detailed view
    DOS command line
    Multiple language support
    Bannato
    1683
    AutoCAD
    Predefinito A43 File Management Utility
    5037
    Variabile
    AutoCAD 2016
    Bannato
    1683
    AutoCAD
    5037
    Variabile
    AutoCAD 2016
    5037
    Variabile
    AutoCAD 2016
    Bannato
    1683
    AutoCAD
    Ultima modifica di arri; 27-01-2008 alle 16: 14
    Bannato
    1683
    AutoCAD
    Unreal Commander
    Two-panel interface
    Extended search of files
    Multi-rename tool
    Dirs synchronization
    Support of archives ZIP, RAR, ACE, CAB, JAR, TAR, LHA
    Built-in FTP client
    Directory tabs
    Support of LS-plug-ins and WCX-plug-ins
    Build-in viewer and quick view function
    Work with a network environment
    Support Drag and Drop at work with other applications
    History and Hotlist buttons
    Background file copying/moving/deleting
    Deleting files with WIPE
    Background pictures support
    Visual styles: color categories of files, fonts for all interface elements
    http://news.wintricks.it/software/si...ommander-0.94/
    2099
    Total Commander.
    Gia' Windows Commander, lo uso da Windows 3.1
    Per me il piu' bel clone di NC di tutti i tempi!!!
    a pagamento, ma ne e' valsa veramente la pena!!!
    http://www.ghisler.com/
    Saluti, Stefano.
    Bannato
    1683
    AutoCAD
    Total Commander.
    buono :) ,
    ma a NortonCommander ho sempre preferito XTreeGold ;)
    1. REVISION MANAGER - COLLEGAMENTO TRA I FILE
      Di fabiovello nel forum Solid Edge
    2. Gestione risorse
    3. Risposte: 6
    4. Gestione File Templates
      Di d.demarco nel forum Inventor
    5. Gestione risorse per file dwg, dwt e dxf
