    Utente Junior L'avatar di MACK
    19
    prima SWX, ora OSD + T3
    Predefinito Penne e testi negli sviluppi
    Salve a tutti
    I miei colleghi mi stanno fracassando i m.….i.
    Vogliono cambiare colore e tipo di linee e testi negli sviluppi in annotation. Non so quale file di personalizzazione il programma legge, è possibile modificare queste informazioni?
    Utilizzo la 15.50b e lo sheet metal base.
    MACK
    Utente Standard L'avatar di and
    100
    Emilia
    CoCreate
    si basta modificare il file sd_data.lsp
    Codice PHP:
     ;; MODIFICA SETUP MODULO LAMIERE BASE
    (persistent-data :key "BASIC-SHEET-METAL-SHOP"
    :value '(
    ;;; 3D SETTINGS (SHEET CREATION)
    :DEFAULT-MATERIAL-THICKNESS 1
    :DEFAULT-BEND-PROCESS "bends" ; do not change!
    :DEFAULT-BEND-RADIUS 1
    ; Default BEND-RELIEF; Posible values: "no_relief" "rect_relief"
    :DEFAULT-RELIEF-TYPE "rect_relief"
    :DEFAULT-RELIEF-TOOL (:WIDTH 1)
    :DEFAULT-RELIEF-DEPTH 0
    :DEFAULT-MITER-RELIEF-TYPE "miter_chamfer" ; do not change!
    :DEFAULT-MITER-RELIEF-TOOL (:PERCT_DEPTH 100)
    ; Default CORNER-RELIEFS; Posible values:
    ; "no_3D_corner_relief" "min_perp_v_corner_relief"
    :DEFAULT-CORNER-RELIEF-TYPE "min_perp_v_corner_relief"
    :DEFAULT-CORNER-RELIEF-TOOL (:MIN_WIDTH 1)
    :DEFAULT-CORNER-GAP 0.1
    ; Possible values for DEFAULT-CORNER-CONSTELLATION:
    ; :MITER :SYMMETRIC :THIS_LIP_LONG :THIS_LIP_HALF_LONG
    ; :OTHER_LIP_LONG :OTHER_LIP_HALF_LONG
    :DEFAULT-CORNER-CONSTELLATION :SYMMETRIC
    :DEFAULT-CORNER-LONG-LIP-OFFSET 0
    ; Lists of available MATERIALS, BENDS (radius) and RELIEFS
    :MATERIALS ((0.5)(1)(1.25)(1.5)(2)(3)(5))
    :BENDS  ((0.4)(0.6)(0.8)(1)(1.5)(2)(2.4))
    :RECT-RELIEFS ((0.01)(1)(1.6)(2)(3)(10)(20))
    ;; Further 3D Options
    :DEFAULT-CHECK-PART t ; t  ; better to keep it to '
    t'!
    :DEFAULT-KEEP-WP nil
    ;;; 2D SETTINGS (FLAT GENERATION)
    ;; Flat generation
    :K-FACTOR 0.4
    :SHARP-BEND-RADIUS 0.4
    :SHOW-MERGEABLE-LINES nil
    :FLAT-SHOW-LABELS t
    :FLAT-PART-NAME "sha-flat"
    :FLAT-TRIM-BEND-LINES t
    :FLAT-SINGLE-BEND-TEXT nil
    ;; Color Settings
    :FLAT-DEFAULT-COLOR (rgb-color 1.0 1.0 1.0) ; 16777215
    :FLAT-FOLD-UP-COLOR 16776960
    :FLAT-FOLD-DOWN-COLOR 16776960
    :FLAT-TOOL-COLOR (rgb-color 0.0 1.0 0.0) ; 65280
    :FLAT-ERROR-COLOR (rgb-color 1.0 0.0 0.0) ; 16711680
    ;; LINETYPE and -WIDTH Settings
    ;; Valid values for below LINETYPE settings :
    ;; 0=SOLID 1=DASHED 2=LONG_DASHED 3=DOT_CENTER
    ;; 4=DASH_CENTER 5=CENTER_DASH_DASH 6=PHANTOM 7=DOTTED
    :FLAT-FOLD-UP-LINETYPE 0
    :FLAT-FOLD-DOWN-LINETYPE 1
    :FLAT-TEXT-SIZE 3.5
    :FLAT-DEFAULT-LINEWIDTH 0
    :FLAT-TOOL-LINEWIDTH 0
    :FLAT-ERROR-LINEWIDTH 0
    :FLAT-FOLD-UP-LINEWIDTH 0
    :FLAT-FOLD-DOWN-LINEWIDTH 0
    ;; Further 2D Options
    :SHOP-UNITS (1 :MM)
    :FLAT-SHOW-REFERENCE-POINT t
    :FLAT-WORKPLANE-OFFSET 0
    Basta che cambi il numero della sezione :
    Codice PHP:
    :FLAT-DEFAULT-COLOR
    :FLAT-FOLD-UP-COLOR
    :FLAT-TOOL-COLOR
    :FLAT-ERROR-COLOR
    Ultima modifica di Stefano_ME30; 13-10-2008 alle 22: 38
    19
    And per la risposta
    sono riuscito a cambiare tutto tranne il font della scritta ed il testo, al posto di up vogliono "asse piega" e al posto di down "asse piega a rovescio"
    MACK
    15
    Libero Professionista
    bologna
    OneSpaceDesigner CoCreate
    Purtroppo queste scritte si cambiano solo nel modulo completo.
    Ciao a Tutti
    100
    Emilia
    CoCreate
    assolutamente no .. io non ho il modulo completo e con queste stringe cambio il colore e vari parametri..
    mi dispiace contraddirti ...
    15
    bologna
    Scusatemi, forse sono stato troppo frettoloso.
    Volevo dire che i testi delle pieghe UP e DOWN non sono modificabili (almeno fino alla versione 2007).
    Ciao a Tutti.
    1. Riqualificazione di piazza Luca da Penne
      Di gfrank nel forum Progetti e concorsi.
    2. [Tavola] Differenziare testi statici e testi di proprietà
    3. Settaggio penne per stampa
      Di Dirotec nel forum OneSpace Designer Modeling
    4. Anomalie sviluppi lamiera SE ST da MP3 a MP5
      Di SE_CP nel forum Solid Edge
    5. Tramogge e altri sviluppi - SPI Ducting
      Di Tarkus nel forum Inventor
