    Bannato
    1683
    AutoCAD
    Predefinito Incrementa il valore degli attributi nei blocchi
    AttInc - After you select a block, the program displays a list of all attribute tags for you to choose from. Then it gives you the options for the starting value, the increment, and the order in which to cycle through the blocks
    http://www.jefferypsanders.com/autolisp_AttInc.html
    Bannato
    1683
    AutoCAD
    http://www.cadtutor.net/forum/showpo...51&postcount=6
    (defun c:mnum(/ stStr stNum nLen cAtr dLst blName
    fLst blLst blSet aName sLst lZer aStr)
    (vl-load-com)
    (if
    (and
    (setq stStr(getstring "\nSpecify start number: "))
    (setq stNum(atoi stStr))
    (setq nLen(strlen stStr))
    ); end and
    (progn
    (if
    (and
    (setq cAtr(nentsel "\nPick attribute > "))
    (= "ATTRIB"(cdr(assoc 0(setq dLst(entget(car cAtr))))))
    ); end and
    (progn
    (setq blName
    (vla-get-Name
    (vla-ObjectIDToObject
    (vla-get-ActiveDocument
    (vlax-get-acad-object))
    (vla-get-OwnerID
    (vlax-ename->vla-object(car cAtr)))))
    fLst(list '(0 . "INSERT")(cons 2 blName))
    aName(cdr(assoc 2 dLst))
    ); end setq
    (princ "\n<<< Select blocks to number >>> ")
    (if
    (setq blSet(ssget fLst))
    (progn
    (setq sLst
    (mapcar 'vlax-ename->vla-object
    (mapcar 'car
    (vl-sort
    (vl-sort
    (mapcar '(lambda(x)(list x(cdr(assoc 10(entget x)))))
    (vl-remove-if 'listp
    (mapcar 'cadr(ssnamex blSet))))
    '(lambda(a b)(<(caadr a)(caadr b))))
    '(lambda(a b)(>(cadadr a)(cadadr b)))))))
    (foreach i sLst
    (setq lZer "")
    (repeat(- nLen(strlen(itoa stNum)))
    (setq lZer(strcat lZer "0"))
    ); end repeat
    (setq atLst
    (vlax-safearray->list
    (vlax-variant-value
    (vla-GetAttributes i))))
    (foreach a atLst
    (if
    (= aName(vla-get-TagString a))
    (vla-put-TextString a
    (strcat lZer(itoa stNum)))
    ); end if
    ); end foreach
    (setq stNum(1+ stNum))
    ); end foreach
    ); end progn
    (princ "\nEmpty selection! Quit. ")
    ); end if
    ); end progn
    (princ "\nThis isn't attribute! Quit. ")
    ); end if
    ); end progn
    (princ "\nInvalid start number! Quit. ")
    ); end if
    (princ)
    ); end of c:mnum
    1. Edit degli attributi da lisp
      Di x11start nel forum Lisp per Autocad
    2. Estrazione degli attributi da un blocco
      Di Zoro76 nel forum Lisp per Autocad
    3. Risposte: 5
    4. Rilevare la posizione bloccata degli attributi
    5. Risposte: 0
