Risultati da 11 a 19 di 19
Discussione: NX10 - OFFICIAL TOPIC
    1797
    NX10/TC10/4GD
    temo di no
    BG UgoverALL - Siemens PLM
    2015
    3
    ingegnere
    Campania
    solidworks, catia V5
    Predefinito siemens NX10
    ciao a tutti,
    Da oggi è disponibile per il download NX10.
    Da dove lo posso scaricare ?
    1797
    NX10/TC10/4GD
    Citazione Originariamente Scritto da enzo_88 Visualizza Messaggio
    Dal sito del GTAC
    https://download.industrysoftware.au...n.siemens.com/
    2015
    3
    ingegnere
    Campania
    Basta solo registrarsi? E' tutto gratuito!
    La ringrazio!
    1797
    NX10/TC10/4GD
    La ringrazio!
    Direi di no.
    NX è un software a pagamento.
    Se sei uno studente puoi accedere ai programmi appositi tramite la tua facoltà
    1797
    NX10/TC10/4GD
    SUBJECT: Certification of NX 10 on Windows 10
    Affected Software: NX 10.0.3
    Associated PR Number(s): n/a
    Scope: Windows 10 Professional and Enterprise
    Revision: n/a
    This is to announce the certification of NX10.0.3 on Windows 10 Professional and Enterprise. The certification process consists of testing the installation and operation of NX on several Windows 10 systems by running the full NX QA suite of tests to verify operation and detect any anomalies. Several minor issues were detected and documented in the following section. It is the position of Siemens PLM Software that these minor issues will not affect the use and performance of NX on Windows 10
    and that this new OS is fully certified and supported for customer use.
    Known Issues:
    1. License server installation. The installation of the license server fails on Windows 10 if Java 8 u60 is used, which was the latest Java version available from Oracle. The install requires Java 8 u45 or Java 8 u51 to operate correctly which can be downloaded from the archives on the Oracle download site. We are investigating newer Java releases and working with Flexera for an updated install that does not exhibit this problem.
    2. The Windows 10 System Theme does not display the Siemens name in the NX title bar. The solution is to not use the System theme. NX development is investigating.
    3. Minor NX start-up performance degradation and resource consumption. It appears there is slightly more overhead associated with Windows 10 that affects the initial load of NX. In addition, additional memory is consumed by NX when compared to Windows 7. However, operational performance does not appear to be affected and in some cases is faster on Windows 10 when compared to Windows 7. (e.g. assembly Save operation)
    Per our standard support policy, once an OS is certified it will remain certified and supported for new releases of NX until an End of Life statement is released. This means that NX11 will be supported on Windows 10 when released.
  7. #17
    820
    UG 11 - NX11 TC10
    Che due m....oni con 'sto Java!
  8. #18
    43
    Creo 2,0 CATIA V5 Solidworks
    Help download nx10
    ciao a tutti
    potete darmi una dritta per scaricare nx10 ?
    Luigi
  9. #19
    820
    UG 11 - NX11 TC10
    Citazione Originariamente Scritto da Bisanzio330 Visualizza Messaggio
    ciao a tutti
    Vai qui https://download.industrysoftware.au...n.siemens.com/ e ti scarichi anche la 11 volendo.
    1. NX9 - Official Topic
      Risposte: 61
    2. NX8.5 - Official Topic
      Risposte: 52
    3. NX8 - Topic Ufficiale
      Risposte: 29
