Discussione: software per superfici
    RUGGIUNO
    Predefinito software per superfici
    Alias - SurfaceStudio avanzato free-from modeling, nuvola di punti, reverse engineering, e
    in tempo reale diagnostica di superficie
    http://www.autodesk.it/adsk/servlet/...036&id=8934938
    ICEM Surf - per la creazione e lo sviluppo delle superfici di classe A, da ICEM
    http://www.icem.com/text.asp?PageId=17
    Rhino - NURBS-based conceptual design and free-form curve, surface and solids modeling tool
    for industrial, product and scene designers . Da Robert McNeel & Associates.
    http://www.rhino3d.com/
    AeroHydro - MultiSurf, marine design, SurfaceWorks per gli utenti di SolidWorks
    http://www.aerohydro.com/
    Cobalt - Ashlar Vellum's high-end modeler, with parametric, free-form surfaces, NURBS and
    ACIS (replaces Vellum Solids)
    http://www.ashlar.com/
    Floating Point Solutions - offre due plug-Ins per Rhino : HPGL Import for Rhino, un Hewlett
    -Packard Graphics Language (. PLT)importatore file , e OBJ Import for Rhino, un Alias |
    Wavefront (. OBJ)importatore file
    http://www.sycode.com/products/index.htm
    IntegrityWare - offre software e servizi per la modellazione geometrica 3D e tecnologia
    grafica , tra cui POPLib, a polygon optimization library, e TSLib, per lo sviluppo di Nurbs
    basato su curve, superfici, trimmed surfaces, solidi o open shells
    http://www.integrityware.com/
    MeshWorks for Rhino - polygon mesh manipulation utilities for Rhino, by Floating Point
    Solutions
    http://www.sycode.com/products/meshcad_rh/index.htm
    Ultima modifica di RUGGIUNO; 01-05-2008 alle 20: 32
    RUGGIUNO
    Paraform - complex, 3D shapes for conceptual design, inspection, reverse engineering,
    digital content creation, more
    http://www.metris.com/
    Pilot3D - a trimmed NURBS surface 3D modeling program, from New Wave Systems
    http://www.pilot3d.com/
    RevEng - an interactive reverse engineering and inspection tool that links to 3D digitizers
    and coordinate measuring machines to create accurate surface and solid models as the part is
    digitized. From Tri-Tech Solutions, Inc.
    http://www.tritechcad.com/
    Raindrop Geomagic Inc. - makers of Geomagic Studio, which enables 3D photography
    applications in manufacturing, engineering and design; and Geomagic Qualify, che consente il
    confronto automatico tra un modello CAD e la parte o l'oggetto costruito
    http://www.geomagic.com/it/products/
    RevWorks - for creating feature-based CAD models and freeform surfaces directly from
    digitized part data. Supporta FARO, ROMER, MicroSCRIBE e CMM. From Revware.
    http://www.revworks.com/
    SCC (Survey Control Center) Surface Modelling - a land survey and modeling package, from
    Atlas Computers Ltd., Dublin, Ireland
    http://www.atlascomputers.ie/SCC-Overview.htm
    solidThinking - concept modeling aimed at industrial designers,
    http://www.solidthinking.com/it/index.htm
    VRMesh - software di modellazione poligonale,disegno basato su forme libere 3D da
    VirtualGrid
    http://www.vrmesh.com/
    1. Consigli per modellazione solida o per superfici e software di render
      Di Dwolf nel forum AutoCAD: Modellazione 3D e Rendering
    2. SADEV SELEZIONA IL SOFTWARE SIMXPERT DI MSC.SOFTWARE
      Di mscsoftware.italia nel forum Notizie importanti (appariranno in Home page)
    3. superfici?
      Di MICHELE77 nel forum Solid Edge
    4. Superfici
      Di siou nel forum Solid Edge
    5. superfici
      Di william nel forum Rhino3D
