    449
    NX8 TC9
    Predefinito Online documentation - Search Issues with Java 7 Update 21
    [ Siemens PLM Software ]
    S O F T W A R E SFB-NX-7396
    F I E L D Page 1 of 1
    B U L L E T I N Issue Date: May 6,2013
    Revision Date: N/A
    Supersedes: N/A
    Submitted By: Tracey Atkinson
    Responsible Group: Teamcenter
    GTAC 800 # Options(s): 2,3,1
    SUBJECT: Online documentation - Search Issues with Java 7 Update 21
    Affected Software: NX 8.5 including MR releases
    Associated PR Number(s): N/A
    Scope: N/A
    Revision: N/A
    PROBLEM:
    There are two symptoms:
    1.When running the documentation from a web server, a Java Security Warning
    is displayed. The user has to Accept that they want to run the applet in
    order for the search to work.
    2.When accessing the help from a local file system (installed to the
    user desktop), a message is displayed that the Application has been
    blocked. In this case the search does not work at all.
    ANALYSIS:
    Oracle has put additional security settings in place with the latest Java
    update 21. These settings are preventing the search applet from running
    with files launched from a local path, e.g. D:/tchelp. Users see a message
    that the application is being blocked. If the user clicks OK, the content
    pages can be viewed, but the search does not work.
    When running from a web server, a Java Security Warning is displayed that
    the user must dismiss in order for the search to work.
    REMEDY:
    We are providing both a fix and a workaround for these issues:
    Fix: Download qagent.jar from Product Updates for NX/Unigraphics NX in the
    patch/customer directory. You will be prompted for the file name.
    The location to install the jar file may vary depending on what version
    of the product/help is installed and where the user has installed the
    help files. The easiest way to locate the qagent.jar is to search for it
    by name, rename it to qagent.jar.bak, then copy the new signed version
    to that location.
    OR
    Workaround: Set the Java security panel setting to Medium on each user’s
    machine:
    1. Pick Start, Control Panel, Java.
    2. On the Java Control Panel, select the Security tab.
    3. Change the Security Level from High (minimum recommended) to Medium.
    Note: The decision to change the Security setting is up to the user and the
    rules at their site.
    This is fixed in NX9.
    If any questions arise regarding this field bulletin, the
    Global Technical Access Center may be contacted at:
    All USA & Canada (800) 955-0000
    If you are outside the United States and Canada, any questions
    regarding this or any other SFB should be directed to your local
    support office, quoting the SFB number.
    To unsubscribe from the SFBMAIL mailing list, click here.
    Grazie...
    Utente Standard L'avatar di ciciu
    137
    Stampi Termoplastici
    Nx8.5 ; Nx10
    x chi lavora in 64bit : attenzione che si sta parlando di java 32 bit (sotto Programmi%86) e non del java 64 - necessario per i convertitori.
    Grazie . Ciao,
    Guido
    1. CREO 2.0 Search Path
      Di TECNICO nel forum Creo Parametric - Configurazione
    2. Problemi di java con i batch translator
      Di Lorenzo77 nel forum NX (Unigraphics)
    3. Search.pro
      Di power23 nel forum Creo Parametric - Configurazione
    4. Risposte: 10
    5. Disabilitare windows search
      Di body nel forum Sistemi operativi e software di uso generale
