Risultati da 1 a 8 di 8
    21
    Progettista stampi
    NX 8.5.1.3
    Predefinito Problemi di java con i batch translator
    Ciao a tutti, da ieri ho un problema con i batch translator di NX aggiornato alla 8.5.1, Java Ŕ la 7u13.
    Praticamente con qualsiasi batch che faccio partire, che sia iges, step o quant'altro ho sempre lo stesso risultato:
    Il file ugii_env.DAT riporta:
    # Copyright 1991 - 2009 Siemens Product Lifecycle Management Software Inc.
    # All Rights Reserved.
    # This file should be used to override any standard NX environment variables.
    # The values defined here will take precedence over the NX values, as long as
    # they are defined before the #include of ugii_env_ug.dat. This file will not
    # be overwritten by an MR installation.
    # Override any variables here.
    # Do not define any variables after the #include below. They must be defined
    # before the #include in order to override the NX defaults.
    #if FILE ${UGII_BASE_DIR}\ugii\ugii_env_ug.dat
    #include ${UGII_BASE_DIR}\ugii\ugii_env_ug.dat
    #endif
    Mentre il file ugii_env_ug.DAT nella sezione interessata riporta:
    # Java NXOpen Environment Variables
    # As of NX 8.5, NX no longer provides a JRE in the installation.
    # UGII_JAVA_HOME should point to the base directory of the JRE Installation.
    # The value below is just an example that will be different on your system.
    # Changing this variable will cause all NX java based applications to use the specified JRE.
    # This is an example of how this value can be set.
    #if x64wnt
    #if FILE c:\apps\Java\jre7x64
    UGII_JAVA_HOME=c:\apps\Java\jre7x64
    #endif
    #else
    #if FILE c:\apps\JavaSoft\jre7
    UGII_JAVA_HOME=c:\apps\JavaSoft\jre7
    #endif
    #endif
    # This is the JVM that will be used for NXOpen Java applications.
    # UGII_JVM_LIBRARY_DIR is set to the directory specified in UGII_JAVA_HOME.
    # NOTE: changing this value only changes the JRE used by NX Open applications.
    # On windows 64 only the server JVM library is in the JRE
    #if x64wnt
    UGII_JVM_LIBRARY_DIR=${UGII_JAVA_HOME}\bin\server
    #else
    UGII_JVM_LIBRARY_DIR=${UGII_JAVA_HOME}\bin\client
    #endif
    Ho provato senza risultato positivo a cambiare in:
    #if x64wnt
    #if FILE c:\Programmi\Java\jre7x64
    UGII_JAVA_HOME=c:\Programmi\Java\jre7x64
    #endif
    #else
    #if FILE c:\Program Files (x86)\JavaSoft\jre7
    UGII_JAVA_HOME=c:\Program Files (x86)\JavaSoft\jre7
    #endif
    #endif
    Non so il perchŔ sia iniziato questo errore, Ŕ un po' che non uso il batch e nel frattempo ho aggiornato java e NX dalla 8.5 alla 8.5.1, avete qualche soluzione?
    21
    Progettista stampi
    NX 8.5.1.3
    Ho trovato un errore, la directory
    in realtÓ Ŕ
    Ho provveduto a correggerla ma il risultato non Ŕ cambiato. :-(
    820
    UG 11 - NX11 TC10
    Ciao Lorenzo,
    devi mettere il path delle directory richieste nel file ugii_evn.dat sotto la riga overryde any variables here.
    NX va a leggere l'ugii_env.dat e se trova delle nuove variabili le sovrascrive nell ugii_env_ug.dat.
    Spero di essere stato chiaro e dimmi se ha funzionato.
    21
    Progettista stampi
    NX 8.5.1.3
    Grazie per il suggerimento Ceschi, comunque non ha funzionato, con i file DAT di NX ho perso. In compenso ho corretto i file CMD dei BATCH e ora funziona tutto, ho aggiunto le famose stringhe di set nei CMD e tutto ha iniziato a funzionare:
    :JAVA_GUI
    set PATH=%BASE_DIR%\UGII;%PATH%
    set PATH=c:\Program Files\Java\jre7;%PATH%
    set UGII_JAVA_HOME=c:\Program Files\Java\jre7
    set UGII_JVM_LIBRARY_DIR=c:\Program Files\Java\jre7\bin\server
    REM allow the user to use their own JRE or JAR
    if "%UGII_DEX_JAR%" == "" set UGII_DEX_JAR=%STEP203UG_DIR%
    if "%UGII_DEX_JRE%" == "" goto CHECKHOME
    REM Check if the jave.exe exist at location defined by UGII_DEX_JRE
    @if not exist "%UGII_DEX_JRE%\bin\java.exe" goto CHECKHOME
    @goto CHECKJRE
    REM UGII_DEX_JRE is not defined, check for UGII_JAVA_HOME
    :CHECKHOME
    @if "%UGII_JAVA_HOME%" == "" goto SETJRE
    @if not exist "%UGII_JAVA_HOME%\bin\java.exe" goto SETJRE
    @set UGII_DEX_JRE=%UGII_JAVA_HOME%
    @goto CHECKJRE
    REM UGII_JAVA_HOME is not defined, check if it is set by ugii env.
    :SETJRE
    @for /f "tokens=*" %%I in (' "%BASE_DIR%\ugii\env_print" UGII_JAVA_HOME') do set UGII_JAVA_HOME=%%I
    REM check the JRE version
    :CHECKJRE
    if defined UGII_JAVA_HOME (
    @if not exist "%UGII_JAVA_HOME%\bin\java.exe" goto JREERROR
    "%UGII_JAVA_HOME%\bin\java" -jar "%BASE_DIR%\ugii\VerifyJava.jar" external "%UGII_JAVA_HOME%"
    ) else (
    echo UGII_JAVA_HOME must be defined
    goto JREERROR
    if errorlevel 1 (
    goto OK
    ) else (
    @goto STARTUI
    :JREERROR
    @Echo The Java Runtime Enviroment (JRE) was not found.
    @Echo Install your own JRE and set UGII_JAVA_HOME
    @Echo in %UGII_BASE_DIR%\ugii\ugii_env.dat
    @Echo to the directory containing the bin and
    @Echo lib directories.
    @pause
    @goto OK
    :STARTUI
    @call "%UGII_DEX_JRE%\bin\java" -classpath "%UGII_DEX_JAR%\dex.jar" -DUGII_BASE_DIR="%BASE_DIR% " -DSTEP203UG_DIR="%STEP203UG_DIR% " com.dex.splash.STEP203SplashScreen
    @IF not %ERRORLEVEL% == 0 pause
    GOTO OK
    Comunque mi piacerebbe sapere perchŔ non mi funzionano correttamente le variabili nel ugii_env_ug.dat...
    820
    UG 11 - NX11 TC10
    Ciao Lorenzo,
    credo di aver capito il perchŔ dell'errore. Non avevo letto attentamente il tuo post iniziale in cui dicevi del BATCH translator. Non funziona proprio perchŔ Ŕ come se 'saltassi' la configurazione di NX che viene attivata quando lo fai partire ma non quando fai partire un comando batch. Per avere la conferma prova a mettere le variabili nell'UGII_ENV.dat (e non nell'UGII_ENV_UG.DAT) nella posizione che ti ho suggerito, lanciare NX e poi vai a vedere il file di log (in Help) e vedrai che le variabili sono correttamente settate.
    Ti consiglio, a questo punto di andare a mettere queste variabili direttamente come variabili di sistema.
    Ciao a presto
    21
    Progettista stampi
    NX 8.5.1.3
    Ho provato a metterle nel UGII_ENV.DAT come mi hai suggerito, ma le variabili nel log file nella sezione ugii_env.dat sono risultate col campo vuoto. Allora le ho messe nel sistema come mi hai suggerito, in questo modo i batch funzionano correttamente e le variabili compaiono correttamente assegnate nel log sezione variabili di sistema e compaiono doppie nella sezione ugii_env.dat.
    Grazie.
    Utente Standard L'avatar di ciciu
    137
    Stampi Termoplastici
    Nx8.5 ; Nx10
    se nel path ci sono spazi , allora quando si mette la variabile nell'env.dat bisogna racchiuderlo tra i doppi apici : UGII_JAVA_HOME="C:\Program Files\Java\jre7"
    Grazie . Ciao,
    Guido
    21
    Progettista stampi
    NX 8.5.1.3
    Grazie ciciu, era proprio questo il problema, nel _ENV.DAT i path con spazi editati nelle variabili vanno racchiusi tra i doppi apici. Adesso ho tolto le variabili dal sistema, le ho inserite con i doppi apici nel UGII_ENV.DAT e ho pulito dalle precedenti modifiche i *.CMD dei batch. Tutto ordinato e funzionante. Grazie a tutti e speriamo non capiti pi¨ nulla per almeno un altro anno.
    1. Risposte: 0
    2. DXF-DWG translator 14.0. ITA
      Di linda69 nel forum Archicad
    3. batch render
      Di studio nel forum 3D studio
    4. CATIA V5 Translator
      Di Preparation-H nel forum Inventor
    5. PRO-BATCH, ESPORTAZIONE DXF
      Di maxopus nel forum Creo Parametric - Messa in tavola
