    Bannato
    1683
    AutoCAD
    Predefinito Cronologia comandi e variabili AutoCAD dalla R12 alla 2011
    Vengono indicate per singola versione, dalla 12 alla 2010, facendo un raffronto, quali comandi sono state introdotte, modificate, mantenute o non più supportate
    http://www.hyperpics.com/commands/
    Vengono indicate per singola versione, dalla 12 alla 2010, facendo un raffronto, quali variabili sono stati introdotti, modificati, mantenuti o non più supportati
    http://www.hyperpics.com/system_variables/index.asp
    Ultima modifica di PlannerRoad; 12-04-2010 alle 00: 18
    Bannato
    1683
    AutoCAD
    Predefinito Tasti acceleratori
    F1 displays help
    F2 displays text window
    F3 switches object snaps
    F4 toggles table mode
    F5 toggles isometric planes
    F6 toggles DUCS (switches coordinate display, till A2006)
    F7 toggles grid display
    F8 toggles ortho mode
    F9 toggles snap
    F10 toggles polar tracing
    F11 toggles object tracing
    F12 toggles dynamic input (2006+)
    ESC cancel changes, cancel grips
    TAB cycles osnaps
    SHIFT (on object selection) removes objects
    DEL erased objects (hold when pointing)
    Ctrl+0 toggles clean-screen mode (2004+)
    Ctrl+1 displays Properties window
    Ctrl+2 displays DesignCenter window
    Ctrl+3 displays Tool palette (2004+)
    Ctrl+4 displays Sheet Set Manager, or Content Manager (2005+, ADT2004)
    Ctrl+5 displays Info Palette, or Project Navigator (2005-2007, ADT2004)
    Ctrl+6 displays dBConnect window
    Ctrl+7 displays Markup Manager (2005)
    Ctrl+8 displays Quick Calculator (2006+)
    Ctrl+9 shows/hides Command line (2006+)
    Ctrl+A selects all thawed objects (2002)
    Ctrl+Shift+A toggles group selection (group/single)
    Ctrl+B toggles snap
    Ctrl+C copies content to Clipboard
    Ctrl+Shift+C copies with reference point
    Ctrl+D toggles coordinates display
    Ctrl+E switches isoplanes
    Ctrl+F toggles osnaps
    Ctrl+G toggles grid display
    Ctrl+H toggles Pickstyle (group and hatch selection)
    Ctrl+J repeats the last command (Enter)
    Ctrl+K displays the Hyperlink dialog
    Ctrl+L toggles Ortho mode
    Ctrl+N starts new drawing
    Ctrl+O opens a drawing
    Ctrl+P print a drawing
    Ctrl+Q quits AutoCAD (2004+)
    Ctrl+R switches to the next viewport
    Ctrl+S saves drawing
    Ctrl+Shift+S saves drawing as (2004+)
    Ctrl+T toggles the Tablet mode
    Ctrl+U switches polar tracing
    Ctrl+V pastes the Clipboard contents
    Ctrl+Shift+V pastes contents as block
    Ctrl+W toggles object tracing
    Ctrl+X cuts contents to the Clipboard
    Ctrl+Y redoes the undone action
    Ctrl+Z undoes the last action
    Ctrl+PgDn switches to the next layout (2004+)
    Ctrl+PgUp switches to the previous layout (2004+)
    Alt+F8 VBA macros
    Alt+F11 VBA editor
    temporary override keys (2006+):
    Shift switches ortho mode
    Shift+- switches dynamic UCS mode (2007+)
    Shift+) switches object tracing mode (2007+)
    Shift+. switches polar mode
    Shift+A switches osnaps
    Shift+E switches endpoint osnap
    Shift+C switches center osnap
    Shift+D disables osnaps and tracing
    Shift+M switches middle osnap
    Shift+Q switches object tracing osnap
    Shift+S enables osnap override
    Shift+X switches polar tracing
    CTRL+mouse cycles selection of overlapping objects (till 2006)
    Shift+space cycles selection of overlapping objects in 2D (2007+)
    CTRL+space cycles selection of overlapping sub-objects in 3D (2007+)
    CTRL+ALT extrudes the selected region into 3D - PRESSPULL (2007+)
    CTRL+arrow moves cursor
    Arrow up/down - command history
    CTRL+SHIFT+letter goes to the property in the Properties window
    ALT+down arrow opens a list in the Properties window
    ALT+up arrow closes a list in the Properties window
    http://www.cad3d.it/forum1/showthread.php?t=2070
    Bannato
    1683
    AutoCAD
    5037
    Variabile
    AutoCAD 2016
    Predefinito Elenco dei comandi in 5 lingue
    Elenco dei comandi di AutoCAD in cinque lingue (Italiano/Inglese/Tedesco/Spagnolo/Francese)
    http://www.braakhekke.de/acadcom.htm
    Utile per chi necessita velocemente di una traduzione del comando in altra lingua.
    Ultima modifica di PlannerRoad; 10-02-2009 alle 18: 16
    5037
    Variabile
    AutoCAD 2016
    Predefinito Cronologia comandi AutoCAD
    Hyperpics ha aggiornato la cronologia dei comandi delle varie versioni di AutoCAD.
    La cronologia questa volta va dalla release 2000i fino alla 2011.
    Qui trovate i comandi:
    mentre qui le variabili:
    1. AutoCAD 2011 va a scatti con alcuni comandi
      Di Alex222 nel forum AutoCAD
    2. Autocad architecture 2011 - Comandi
      Di Giampu89 nel forum Autocad architecture (ex ADT)
    3. Risposte: 5
