Risultati da 1 a 1 di 1
Discussione: [Recuperato] piping
    2098
    Predefinito [Recuperato] piping
    Grazie per la collaborazione.
    Oldwarper.
    ridolino
    15-12-2003, 18.45.30
    :-( ciao a tutti desidero info sul piping....come si possono creare tubi personalizzati
    e e cosa bisogna creare per partire con pezzi disegnati .senza usare le parti della libreria....GRazie
    m.sambo
    22-12-2003, 12.26.13
    Salve Ridolino,
    il nuovo applicativo di SolidWorks per il piping si chiama Routing. Riporto di seguito quanto riportato all'indirizzo http://www.solidworks.com/pages/prod...SWRouting.html del sito di SolidWorks
    Routed Systems Design Software and Fitting Library
    Chiller skid system designed using SolidWorks Routing
    (click image to expand) http://www.solidworks.com/pages/prog...ier_Skid01.jpg
    Image courtesy , Wes Mosier at Applied Engineering Services, Inc.
    Perform routed system design tasks easily and automatically. Speed up the process of routing tubes, pipes and electrical cable routes. With SolidWorks Routing, you’ll enjoy greater design efficiency, better designs, improved BOM accuracy, faster time-to-market, and lower costs.
    Streamline the design of machinery, equipment, small facilities, or anything else that requires routing tubes, pipes and cables. All it takes is SolidWorks Routing, the powerful routed systems design application and fittings library that’s fully integrated with SolidWorks.
    Some of the advantages of SolidWorks Routing include:
    Parametric and associative relationships for routes with other assembly components
    Automatic insertion of elbows into sketches at bends (for piping)
    Design of pipe and tube routes with both elbows or bends
    Option for creating custom butt-welded elbows when angles deviate from standard values
    Fast drag-and-drop insertion of fittings using snap-to-fit SmartMates
    Creation of penetration cuts involving pipes and tubes
    Automatic generation of accurate tube, pipe and cable cut lengths for BOM
    Intuitive, drag-and-drop of components into a route
    Easy click-and-drag modification of existing routed system designs
    Powerful copy and mirror capabilities for routes
    Improved design productivity through automation of routed system design tasks
    Time-saving library of ready-made tube, pipe and cabling components
    Create flexible tube and hose routes
    Generate bend data file generation for CNC tube/pipe bending machines
    Automatic filtering of component selections to match the size and specification of the route
    Generation of routed system and instrumentation diagrams (P&IDs) in SolidWorks using fully integrated Microsoft® Visio® Professional.
    SolidWorks Routing uses the familiar SolidWorks 3D mechanical design environment, so it’s quick and easy to use. Your routed systems design is done in the same integrated package as your equipment design.
    Che intendi per "partire da pezzi disegnati"? Modelli 3D di libreria creati da te?
    Michele
    ridolino
    22-12-2003, 23.08.04
    Grazie per avermi risposto...Michele
    trovo difficile spiegarti il mio problema...ci provo
    vorrei crearmi un tubo personalizzato diam. 8est. 6 interno questo tubo dovrebbe essere passato tra vari punti nei vari pezzi di assieme
    ho letto l'aiuto in linea ma non ne vengo fuori. forse non riesco a mettere quello che il prg vuole.Usando la libreria standard riesco a creare qualcosa
    premetto che vengo da esperienza SE e sono neofita di SW
    mi farebbe piacere che mi telefonassi
    poi ti richiamo non voglio gravarti di spese :-)
    348 --------- Ciao e intanto buone feste.....Francesco
    Ultima modifica di Sandra_ME30; 09-04-2008 alle 01: 30
    Saluti, Stefano.
    1. [Recuperato] Acquisto Cad 3d per piping
      Di RUGGIUNO nel forum Impiantistica Industriale
      Risposte: 86
    2. HELP PIPING
      Di User1 nel forum CATIA V5 CATProduct
    3. Pro/Piping
      Di AMinati nel forum Creo Parametric - Assemblaggio
    4. Progettazione piping
      Di enfact nel forum Solidworks
    5. [Recuperato] software progettazione piping
