Risultati da 1 a 10 di 18
    1069
    SolidWorks 2013 SP1.0
    Predefinito Novità SolidWorks 2012
    Questo è un copia e incolla per non lasciare a errate traduzioni, fraintendimenti o speculazioni di alcun genere :
    1.You can pin your most commonly used files inside the Recent Documents dialog. You can also open the folders those files are in from the dialog as well. (All of this is available from the file menu as well.)
    2.You can now change units with the Units Switcher in the right side of the status bar. (Can change on the fly anytime.)
    3.Sheet metal flanges now have the option to be set to “Parallel to base flange” instead of vertex which allows for better control when flange angles change.
    4.You can now reference the outside tangency to ensure flange lengths stay the same and corners close properly
    5.Easier placement of Form Tools. You can also dynamically flip, rotate and utilize configurations of your forms! (Thumbs up for sure on the configurations!)
    6.You can now select faces to ignore when unfolding sheet metal parts.
    7.New Swept Flange feature for Sheet Metal.
    8.Place one diameter dimension and the sketch automatically locks into diameter dimension mode.
    9.Equation Editor is all new. There is a single dialog box and the software not AUTOMATICALLY calculates the solve order. There are several different views incorporated such as Category, Dimension, & Ordered view. You can access ALL dimensions of a part from a list as well. File properties, functions, & global variables are all available from drop down boxes. You can also utilize the Measure tool from within the Equation Editor to create a reference dimension on the fly which can be used as part of the equation.
    10.Exploded views are now available from the Drawing Pallette. They can also be enabled in the PropertyManager or from the Right Mouse Button Menu. (In current versions, the option to show an Exploded view is buried in the view properties dialog box.)
    11.Bill of Materials can now be created without pre-selecting any views.
    12.Balloons have several enhancements. You can Auto-Balloon sequentially. This will allow you to pick the location of your item 1 balloon and then your balloons follow in sequential item number order around the view (the placement shape is still based on standard Auto-Balloon options). The whole setup appears to be very configurable and will allow you to make adjustments to the balloon sequencing on the fly with all associated Balloons and Bills of Materials dynamically updating.
    13.Balloons now have magnet lines. This is a very popular feature of 3dvia Composer. Balloons can be positioned along a magnet line and you have complete control over the spacing along that line.
    14.View labels are now automatically re-used when views are deleted.
    15.Centermarks can now be automatically inserted at any time for an entire view. (Not just during view creation.) You still have a variety of options for the insertion.
    16.3dvia Composer has enhanced realtime rendering tools which result in a higher quality display image. There is also a Compass tool which helps you navigate and change the appearances of your models.
    17.3dvia Composer also now features BOM highlighting. This allows the user to highlight components in a BOM by hovering over the corresponding components in the model view.
    18.Much like the Magnet Lines mentioned earlier, SolidWork has incorporated some other 3dvia Composer functions. One of which is pressing the Tab key to hide components in an assembly.
    19.SolidWorks 2012 includes a brand new Costing Tool. It analyzes the model (including the features) and gives breakdowns of cost by manufacturing process. It even includes areas where machine setup costs can be input so that quantity adjustments can update the individual component cost. All of this is based on templates which can be modified using an included Template Editor.
    20.Simulation now supports motion sensors and Design Studies support motion simulation. Optimization is also now available in motion simulation.
    21.There is a new Large Design Review mode which allows you to open large assemblies in seconds. (it was described as Quickview on steroids). When opened in this mode the assembly can be navigated as if it were a small assembly. Zooming and panning is also smooth. You can create or reuse Walk throughs and have full interactivity with the FeatureManager Designtree. Hide/Show status can be set from the tree or the graphics area. You can also use the Section View tool while in this mode! Components and sub-assemblies can be opened with full editing capabilities. If you modify the component or sub-assembly and Save it, it will update the Large Assembly already open in Large Design Review mode.
    22.During the SolidWorks World Top Ten Enhancement requests, it was mentioned that the “Freeze Feature” that was shown at SolidWorks World 2010 will be included as part of the SolidWorks 2012 release. (It was in early SolidWorks 2011 alpha builds but was not included in the final SolidWorks 2011 release after some user feedback to questions posted in the SolidWorks Forums. It was held back primarily so that more features and options could be added to it (including support for configurations).
    129
    Programmatore
    SW
    La 9 potrebbe essere veramente utile per come lavoro io
    1069
    Il video di Large Design Review.
    2822
    Pane e lamiera
    Ora si che è chiaro: hanno speso tutte le risorse per sviluppare
    la versione futura... lasciando questo 2011 un pò... zoppo.
    E noi paghiamo.
    Speriamo che Reggio non guardi questo video, gli girerebbero le balle, ha problemi
    a ripetere più di mille volte una ripetizione... figuriamoci se vede questo video che ci fà
    vedere quello che non hanno voluto inserire nella versione attuale.
    1069
    Citazione Originariamente Scritto da Brigno Visualizza Messaggio
    Perchè non usi DriveWorksXpress ?
    Con uno o più database, puoi configurare una intera macchina, senza dover subire i tempi di ricalcolo dovuti alla rigenerazione delle equazioni.
    Questo è compreso nella versione base.
    Se le tue esigenze sono superiori, puoi passare a TuctonWorks o al brand DriveWorks.
    Occorre però prima sapere le tue esigenze.
    1069
    E noi paghiamo.
    Tutti i software di un certo peso, hanno un anno di transizione.
    Lo è per i sistemi operativi, vedi quelli di Microsoft, Apple e Linux.
    Lo è per i CAD (SolidWorks, SE, IV, NX e Catià).
    Lo è per i browser..vedi IE, Firefox e Chrome.
    Inoltre lo è per l'hardware e le macchine di consumo.
    Devi uscire con qualcosa di nuovo, altrimenti perdi quote di mercato e fallisci.
    Nel frattempo migliori e sviluppi.
    E' così a casa di tutti.
    2292
    Veneto - Austin (TX)
    Per quando è prevista l'uscita della 2012?
    1069
    Nessuna informazione a riguardo, ma negli ultimi anni sono sempre state rilasciate nelle prime settimane di Settembre.
    Non ho visto grandissime novità nella parte FEM (es. mi piacerebbe che fosse sviluppata meglio la gestione delle shell e dei compositi). Qualcuno ne sa di più?
    MP-ProgettazioneMeccanica
    129
    Programmatore
    SW
    Ottima la 9.
    A) spero abbiano aumentato la velocità e sfruttato meglio le X CPU dei nuovi PC.
    B) anche la velocità negli schizzi (specialmente quando si importano disegni 2D complessi....tremendamente lento...il CAD 2D che ho sullo smartphone è più veloce ).
    C) stabilità
    D) quando si lavora con particolari con lo stesso nome ma presente in differenti directory "perde" il collegamento al file iniziale....ASSURDO !
    1. AutoCAD 2012 - Notizie
      Di PlannerRoad nel forum AutoCAD
      Risposte: 57
    2. Prime novità su RAC 2012
      Di alpearchitetto nel forum Revit
      Risposte: 22
    3. Ma è uscito revit 2012?
      Di render54 nel forum Revit
      Risposte: 58
    4. Indiscrezioni su Revit 2012
      Di gfrank nel forum Revit
    5. AutoCAD Beta 2012
      Di alpearchitetto nel forum AutoCAD
