Risultati da 1 a 7 di 7
Discussione: E' uscita la NX7.5.2
    1797
    NX10/TC10/4GD
    Predefinito E' uscita la NX7.5.2
    Ciao a tutti.
    E' disponibile per il download la NX7.5.2...
    Sarà FORSE la versione di Block Point 2011 di FGA/CGA.
    Contiene molte cose molto interessanti soprattutto per chi fa Routing e CAE, inoltre, per i "fan" del 2D ha la possibilità di rendere "indipendente" una vista di dettaglio.
    ... e non dimenticate la grande novità della 7.5.1:
    Mechatronics Concept Designer is an application that you use to simulate the complex motion of mechanical systems interactively. It is designed to support the early machine design phase that provides the basic machine concept including the mechanical, electrical, fluid, and software aspects. It is a solution that transforms the machine creation process into an efficient mechatronics design approach.
    This application is built on the following principals:
    Functional machine design
    One of the main instruments in this is the functional model, which forms the foundation to provide an interdisciplinary view of the mechatronics system machine. It lets you lay the foundation for collaboration in detailed design by supporting the early design phase with a functional design approach.
    The functional model provides the link between the data management of the different disciplines and the requirements. This enables the traceability of the customer demand data down to the design departments. Further, the functional model provides a supporting structure to come up with initial design concepts and has the features to perform an evaluation of design alternatives.
    Early system validation
    Mechatronics Concept Designer introduces a verification technology that is built on a new simulation engine. It helps validate concept designs at a very early stage of the development process.
    Multidisciplinary support
    Mechatronics Concept Designer facilitates interdisciplinary concept design up front. The following disciplines can jointly work on a project:
    Mechanical engineer creates the design based on 3D shapes and kinematics.
    Electrical engineer help select and position sensors and actuators.
    Automation programmer designs the basic logical behavior of the machine. He starts with time based behavior and then defines the event based control.
    Modularity and reuse
    Mechatronics Concept Designer provides the ability to capture knowledge in components and store them in a library to enable the reuse of this knowledge in other projects. Since the library components are based on already proven concepts, it improves the design quality and speeds up development.
    Mechatronics Concept Designer supports the definition of functional units such as those in the VDW Standard Funktionsbeschreibung.
    S O F T W A R E SFB-NX-5686
    F I E L D Page 1 of 1
    B U L L E T I N Issue Date: Nov 8, 2010
    Revision Date: N/A
    Supersedes: N/A
    Submitted By: Ben Broad
    Responsible Group: NX CAD App
    GTAC 800 # Options(s): 2-1
    SUBJECT: Maintenance Release NX 7.5.2 is now available
    Affected Software: NX 7.5
    Associated PR Number(s): N/A
    Scope: Windows XP 32 & 64-Bit, Linux 64-Bit, Mac OS
    Revision: N/A
    Dear Siemens PLM Customer,
    We are pleased to inform you that Maintenance Release NX 7.5.2 is now available for download from the Siemens PLM FTP server. NX 7.5.2 is an accumulation of fixes built for installation on top of Windows XP 32-Bit, Windows XP 64-Bit, Linux 64-Bit and Mac OS images of NX 7.5.0.
    Please note that Maintenance Release NX 7.5.2 will only be shipped (on DVD) by request.
    Select the following link to download this maintenance release or to review the README. Note: A valid WebKey account is required.
    Windows XP 32-Bit & 64-Bit:
    http://ftp.ugs.com/unigraphics/maint...se/nx75/winxp/
    Linux 64-Bit:
    http://ftp.ugs.com/unigraphics/maint.../nx75/linux64/
    Mac OS:
    http://ftp.ugs.com/unigraphics/maint...se/nx75/macos/
    Please refer to the README file for maintenance release installation instructions.
    Sincerely,
    Siemens Product Lifecycle Management Software Inc.
    Industry Sector
    1297
    non lo so più nemmeno io
    NX4-NX6-NX8
    Cosa intendete per Block Point 2011 di FGA/CGA.
    perdonami ma le sigle sono sempre più ostiche
    Rivenditore Stampanti 3D
    www.ipdesign.it
    1797
    NX10/TC10/4GD
    Scusami...
    BLOCK POINT = Momento in cui si cambia la release del software
    FGA = Fiat Group Automobilies
    CGA = Chrysler Group Automobiles
    ... non è ancora detto... potrebbe anche essere la NX7.5.3 che conterrà alcune cose interessanti sulla parte di modellazione parametrica.
    2
    progettista automotive
    GERMANIA
    ug nx 5.0
    Salve,
    sapete dire quale e`l'attuale versione UG NX usata da FGA /CGA e quando intendono cambiare release?
    Scusate errori grammaticali, ma non sono abbituato a scrivere in italiano.
    1297
    NX4-NX6-NX8
    Citazione Originariamente Scritto da XERXE Visualizza Messaggio
    Salve,
    Beh direi che se scrivessi io il tedesco come hai scritto tu in italiano ...
    i miei complimenti
    per la risposta alla tua domanda credo ne sappia di più Matrix e non tarderà sicuramente a rispondere
    www.ipdesign.it
    1797
    NX10/TC10/4GD
    Salve,
    Attualmente:
    NX 5.0.5.3 MP4
    TC 2007.1.8.4
    è in previsione il Block Point a fine Giugno 2011:
    NX 7.5.3
    TC 8.3.1.1
    ... Diciamo, allo stato attuale dei test...
    Se verranno fuori problemi ci saranno delle Hot Fix o MP...
    BG UgoverALL - Siemens PLM
    2
    GERMANIA
    ug nx 5.0
    grazie 1000
    1. MEC-SPE 2011 - prima uscita di Mech-Net
      Di Meccbell nel forum Notizie importanti (appariranno in Home page)
    2. Notizie sull' uscita di Solid Edge ST3?
      Di morgan65 nel forum Solid Edge
    3. Come impostare le corse di uscita e ritorno di un estrattore svincolato
      Di beppe296551 nel forum Stampaggio industriale
    4. uscita programma senza motivo
      Di mali_fx nel forum Creo Parametric - Configurazione
