    2874
    teorico del paleocontatto
    Veneto (PD)
    Predefinito MP10 per solid edge ST2
    Hanno rilasciato l'MP10 di aggiornamento per la ST2...
    This Maintenance Pack addresses the following PRs:
    =====Assembly=====
    PR 6414800: Many times when you push the DELETE on the keyboard the selected object will not delete
    PR 6419162: Part cannot be placed in assembly
    PR 1787825: Editing failed relationships causes an abort
    PR 6400068: Assembly feature cutout results in a warning while in the command
    PR 6414695: Crash while in the Assembly explode environment
    PR 1797621: Standard Part properties are not correctly transferred to Solid Edge
    PR 1803424: Fix made based on submitted Crashlog
    PR 2130783: problem in gear accuracy
    PR 6401140: Frequent aborts after upgrading to ST2 from v20
    =====Draft=====
    PR-1805938: Wrong position of Part List in SE ST2 for drawing files created in SEv20
    PR 2154348: Updating a drawing view results in a memory error
    PR 1804408: Aborting while creating a revolved protrusion
    PR 1804916: Angular dimension from create3D causes a crash when retrieved
    PR 1805209: Solid Edge aborts when a user drags symbols or blocks into Draft
    PR 1807348: Parts list is deleted when a quick sheet template is created
    ===Insight/View & Markup===
    PR 6353576: Rev Mgr set path takes minutes to open folders on Windows 7
    =====Part/Profile/Sheet Metal=====
    PR 6255537: Changing Datum Reference terminator to a line causes the DR to move with rotate
    PR 6258876: Dimension does not behave as expected in synchronous sheet metal file
    PR 6414458: Part disappearing from pathfinder when moving a face in assembly
    PR 6409937: File Save causes an abort with these two files
    PR 1805485: Occurrences are not unsuppressed when removing a region in a 2d profile pattern.
    PR 6275277: Failure moving face on CF with circle cutout closed corners
    ===== Solid Edge Embedded Client=====
    PR 1795522: Wrong types of Item object created for SE datasets
    PR 1800220: Extremely long open time after Migration from V20 / WSS2 to ST2 / WSS3
    PR 1807349: Empty JT-file in TcX-Viewer
    PR 6423172: Cannot edit child first time after replacing in assembly structure
    PR 6414597: When you In-Place-Edit a component it will be READONLY
    PR 6354328: Data Prep - Analyze Errors on Part Linked to Excel file
    PR 6411449: Files remain checked out after AddToTeamcenter
    End
    Gianluca...alias Tequila
    952
    Romagna
    certi errori sono sconcertanti, per fortuna di 'abort' non ne ho visti molti, ma di file in v20 ne ho tanti!!
    con mp9 sto incontrando parecchi problemi in esporta in altri formati, e qui non mi parla (eccetto jt che non uso). vedremo...
    952
    Romagna
    per chi usa Insight : NON AGGIORNARE al MP10. (nuova comunicazione Siemens) http://ftp.ugs.com/solid_edge/ST2/SolidEdge/32bit/MP10/
    Io ho notato una cosa strana (ho già la MP10):
    - nel draft , mettendo in tavola un asm che contine varianti, in proprietà della vista in "visualizza" Elenco Parti: ,
    si vede:
    file.asm!Variante!Variante:1 , idem per i sottoassimi con varianti.
    Lo fa anche a voi?
    Non mi sembra comunque che comporti problemi sulle viste.
    Ho controllato via VB: MsgBox (objDoc.ActiveSheet.DrawingViews.Item(1).ModelMemb ers.Item(1).FileName)
    e restituisce:
    file.asm!Variante1
    2874
    Veneto (PD)
    non ho varianti sugli assiemi che faccio perchè in ufficio li gestiamo in modo diverso, però ci do un'occhiata per vedere se lo fa anche a me.
    1. Risposte: 15
    2. Risposte: 36
    3. Risposte: 8
    4. Risposte: 2
