Risultati da 1 a 1 di 1
    5037
    Variabile
    AutoCAD 2016
    Predefinito Abbreviazioni comandi da tastiera
    The standard AutoCAD menu (MNU/MNS/CUI) defines the following hotkeys:
    F1 displays help
    F2 displays text window
    F3 switches object snaps
    F4 toggles table mode
    F5 toggles isometric planes
    F6 toggles DUCS (switches coordinate display, till A2006)
    F7 toggles grid display
    F8 toggles ortho mode
    F9 toggles snap
    F10 toggles polar tracing
    F11 toggles object tracing
    F12 toggles dynamic input (2006+)
    ESC cancel changes, cancel grips
    TAB cycles osnaps
    SHIFT (on object selection) removes objects
    DEL erases objects (hold when pointing)
    Ctrl+0 toggles clean-screen mode (2004+)
    Ctrl+1 displays Properties window
    Ctrl+2 displays DesignCenter window
    Ctrl+3 displays Tool palette (2004+)
    Ctrl+4 displays Sheet Set Manager, or Content Manager (2005+, ADT2004)
    Ctrl+5 displays Info Palette, or Project Navigator (2005-2007, ADT2004)
    Ctrl+6 displays dBConnect window
    Ctrl+7 displays Markup Manager (2005)
    Ctrl+8 displays Quick Calculator (2006+)
    Ctrl+9 shows/hides Command line (2006+)
    Ctrl+A selects all thawed objects (2002)
    Ctrl+Shift+A toggles group selection (group/single)
    Ctrl+B toggles snap
    Ctrl+C copies content to Clipboard
    Ctrl+Shift+C copies with reference point
    Ctrl+D toggles coordinates display (dynamic UCS, till 2009)
    Ctrl+E switches isoplanes
    Ctrl+F toggles osnaps
    Ctrl+G toggles grid display
    Ctrl+H toggles Pickstyle (group and hatch selection)
    Ctrl+Shift+H toggles Palettes display (2009+)
    Ctrl+I toggles coordinate display (2009+)
    Ctrl+J repeats the last command (Enter)
    Ctrl+K displays the Hyperlink dialog
    Ctrl+L toggles Ortho mode
    Ctrl+N starts new drawing
    Ctrl+O opens a drawing
    Ctrl+P print a drawing
    Ctrl+Shift+P toggles Quick Properties display (2009+)
    Ctrl+Q quits AutoCAD (2004+)
    Ctrl+R switches to the next viewport
    Ctrl+S saves drawing
    Ctrl+Shift+S saves drawing as (2004+)
    Ctrl+T toggles the Tablet mode
    Ctrl+U switches polar tracing
    Ctrl+V pastes the Clipboard contents
    Ctrl+Shift+V pastes contents as block
    Ctrl+W toggles object tracing
    Ctrl+X cuts contents to the Clipboard
    Ctrl+Y redoes the undone action
    Ctrl+Z undoes the last action
    Ctrl+PgDn switches to the next layout (2004+)
    Ctrl+PgUp switches to the previous layout (2004+)
    Alt+F8 VBA macros
    Alt+F11 VBA editor
    temporary override keys (2006+):
    Shift switches ortho mode
    Shift+- switches dynamic UCS mode (2007+)
    Shift+) switches object tracing mode (2007+)
    Shift+. switches polar mode
    Shift+A switches osnaps
    Shift+E switches endpoint osnap
    Shift+C switches center osnap
    Shift+D disables osnaps and tracing
    Shift+M switches middle osnap
    Shift+Q switches object tracing osnap
    Shift+S enables osnap override
    Shift+W starts SteeringWheel (A2009+)
    Shift+X switches polar tracing
    CTRL+mouse cycles selection of overlapping objects (till 2006)
    Shift+space cycles selection of overlapping objects in 2D (2007+)
    CTRL+space cycles selection of overlapping sub-objects in 3D (2007+)
    CTRL+ALT extrudes the selected region into 3D - PRESSPULL (2007+)
    CTRL+arrow moves cursor
    Arrow up/down - command history
    CTRL+SHIFT+letter goes to the property in the Properties window
    ALT+down arrow opens a list in the Properties window
    ALT+up arrow closes a list in the Properties window
    Of course all the Windows shortcut keys remain active as well (Ctrl+Tab, Ctrl+F3, Ctrl+F6 etc.).
    Other shortcuts may be defined as user keys in the ACCELERATORS section of your AutoCAD menu. Since AutoCAD version 2006 you can also use CUI to define so called temporary override keys.
    http://www.cadforum.cz/cadforum_en/qaID.asp?tip=5976
    Ultima modifica di PlannerRoad; 10-02-2009 alle 12: 09
    1. Risposte: 9
    2. Comandi rapidi da tastiera.
      Di MAXUS nel forum CATIA V5 Infrastructure
    3. Risposte: 7
    4. Personalizzazione comandi a tastiera
    5. Settaggio comandi da tastiera
      Di stef_design nel forum CATIA V5 Infrastructure
