Risultati da 31 a 34 di 34
Discussione: ST2 mp3
  1. #31
    9341
    Citazione Originariamente Scritto da giotama Visualizza Messaggio
    Grazie! allora mi sa che disinstallo!
    Penso che convenga, se la Siemens dice di fare cosi', e sanno benissimo di tirarsi addosso gli insulti dei clienti e l'ironia della concorrenza, si vede che e' necessario....
    Non se qualcuno si ricorda, ma anni fa, ai tempi della V14, c'era stato un problema simile con un sp. La cura era stata distribuita col sp successivo.
    Per la cronaca il problema si era verificato anche a casa dei cugini della solidworks che usavano lo stesso kernel.
  2. #32
    546
    Ufficiale tecnico
    Solid Edge ST9
    Scusate se non traduco ma è sabato e ho comunque casino in ufficio...
    "Here are some additional details that will hopefully help answer your
    questions:
    Problem Details:
    MP3 introduced a problem when editing a feature and placing a
    dimensional constraint to the model�s edge. This action will cause other
    relationships to fail and a �Feature Regeneration� message to display,
    stating �Unable to maintain all feature relationships during update. Use
    Error Assistant to correct any features that did not update properly.�
    This problem was also reproduced when editing an intermediate feature
    and placing a dimensional constraint to the feature geometry. Once the
    command is exited, some features were failed or warned with the
    following message in PromptBar: �System Error encountered during
    evaluate�.
    Any files that were saved after this type of failure can be repaired
    manually, but development is working on a tool to repair them
    automatically. If you happen to encounter the messages above while
    working in MP3 you can exit the file without saving (sorry you will lose
    any work up to that point) and move back to MP2. The file will open in
    MP2 and the failed relationships will be back like they were prior to
    the failure.
    Recommended Actions:
    Anyone who installed MP3 should remove Solid Edge ST2, reinstall Solid
    Edge ST2, and then apply MP2 to avoid this issue.
    If you continue to use MP3 you run the risk of encountering constraint
    and relationship failures in any part you edit and apply new dimensional
    constraints, etc� that will need to be manually fixed up, only to fail
    again if you need to make subsequent edits.
    Current Actions:
    Development is working on the tool to repair the files. Once the tool
    is available notifications will be sent to those who downloaded MP3,
    posted on the newsgroup, and or others that have experienced either
    problem while running MP3.
    What�s Next?
    In order to avoid confusion over having the �correct version of MP3�,
    we will not repost another MP3. We will be providing the fix to the
    constraint/relationship failure, along with all other fixes that were
    included in MP3 an all new Solid Edge ST2 maintenance pack release,
    MP4.
    MP4 is scheduled to be available for download in mid to late March."
  3. #33
    41
    prog mec
    abruzzo
    solid edge
    fortunatamente non ho avuto il tempo di istallarlo.....
  4. #34
    2874
    teorico del paleocontatto
    Veneto (PD)
    Predefinito ST2 mp 4
    hanno rilasciato l' mp4 per la ST2.
    Io l'ho scaricato ma per ora aspetto qualche giorno prima di installarlo...non vorrei mai che la sfortuna si faccia di nuovo viva
    Gianluca...alias Tequila
