Risultati da 1 a 10 di 34
Discussione: ST2 mp3
    2874
    teorico del paleocontatto
    Veneto (PD)
    Predefinito ST2 mp3
    hanno rilasciato il maintenance pack 3 per solid edge ST2
    Product: Solid Edge
    Version: 102.00.03.04
    Date: 03-Feb-2010
    This release of Solid Edge has been certified to run on the following:
    - Windows XP Professional© operating system (32-bit or 64-bit)
    - Windows Vista Business© or Vista Enterprise© operating system (32-bit or 64-bit)
    - Windows 7 Professional©, Enterprise©, or Ultimate© operating system (32-bit or 64-bit)
    - Internet Explorer 7 or 8 (IE 6.0 minimum)
    Maintenance Packs are all inclusive and can be installed on top of the base
    release or any released Maintenance Pack.
    This Maintenance Pack can be installed on top of Versions:
    102.00.00.116, 102.00.01.04, 102.00.02.06
    End of Release Notes
    Installation Notes:
    After downloading the Maintenance Pack to your machine, dbl click the downloaded
    file and the Maintenance Pack will install.
    End of Installation
    This Maintenance Pack addresses the following PRs:
    =====Part/Profile/Sheet Metal=====
    PR 1746333: Select Manager - Equal Radius does not select all radii that are equal
    PR 1756178: Unable to locate keypoints after exiting profile environment - when IPA
    PR 1759127: Unable to create a Swept Protrusion as in previous versions
    PR 1760836: Switching to Material Outside changes flange length tremendously
    PR 1765687: Countersink hole on wrong side of flat pattern
    PR 6188740: Cannot edit a cylindrical dimension after a Jog or Bend
    PR 6223856: Cannot move a group of faces regardless of the Live Rule settings
    PR 6225736: Moving a face until it fails removes color on faces
    PR 6231047: Unable to move face of a revolved protrusion in this converted synchronous part
    PR 6248295: Color overrides are lost after moving a thickness face on converted or imported part
    PR 6258514: Options button goes away during Section view command
    PR 6266350: QuickPick on 2D constraints
    PR 6268499: Failure moving a flange in one direction, succeeds on another
    PR 6268537: Close Corner fails when adjacent face has a through-all hole
    PR 6271426: Cannot rotate a face on a Contour Flange a 2nd time
    PR 6271535: Temperature loads are not being calculated correctly for thermal expansion
    PR 6271683: Cannot edit the model after a cutout interacts with bend/close corner
    PR 6272188: Bend regions do not merge correctly when closing a cross-bend cutout
    PR 6272409: Operation Unsuccessful moving face on Contour Flange
    PR 6272878: Thickness faces do not merge when creating Contour Flange
    PR 6273983: Need to prevent the creation of a Contour Flange on a circular tab
    PR 6274434: Unable to add procedural feature to circular flange pattern
    PR 6274536: Regression editing a Contour Flange with Concave corner
    PR 6276005: Moving a thickness face on this part causes cutout to change size
    PR 6279114: Contour Flange does not go to tangents of bend if profile has curve outside the face
    PR 6281152: Changing depth of tapered hole during placement is not being handled properly
    PR 1766139: Simulation Express cannot analyze small parts; meshing fails
    PR 6244242: Unable to change direction of dimension edit on chained dimension
    PR 6251970: After rotating face you cannot move any faces on model
    PR 6259374: Simulation is using the old Femap mesher
    PR 6263297: Switch to flat pattern in synchronous sheet metal causes views to go out-of-date
    PR 6269384: Live Rules - inconsistent behavior depending on when selected
    PR 6269974: Crashlogs for Windows 7 list the OS as Vista
    PR 6272097: After failure editing dimension in glass sheet mode you get a "break" Failure
    PR 6272411: File has a pattern that you cannot delete
    PR 6276824: Cannot delete a Contour Flange with Closed Corner or small Circle cutout
    PR 6277695: Cannot create a 360 degree internal hem in synchronous sheet metal
    PR 6283174: Hang when editing a dimension value and pressing Enter and another key simultaneously
    PR 1754499: Certain constraint conditions are not reporting errors
    PR 1765060: Problem with Neutral Factor
    PR 1766833: Custom bend formula does not work correctly on STEP imported PSM
    PR 2086784: Assembly section view not cutting the body
    PR 6114037: Unable to rotate part faces
    PR 6258865: Undo is being disabled when editing the profile of non-base features
    PR 6260823: Display performance during dynamic rotate is bad
    PR 6285483: Fixed distance is not maintained when editing an Angular dimension
    PR 6287803: Problem with weldment running out of memory after edit
    PR 6288372: Select command is not available in Customize QAT
    PR 6288463: Dimension group is collapsed in profile environment at low resolution
    PR 1753048: Problem editing threads
    PR 1767777: Impossible to modify material thickness of the provided sheet metal model
    PR 6267593: Thread lines in draft are lost after a face move
    PR 6296531: Incorrect 'Mapped Meshing Option' is used
    =====Assembly=====
    PR 1702605: Parts have wrong position after replace part, but system gives no error
    PR 1762724: The relationship icon is not updating correctly when switching to FlashFit
    PR 1762903: Unsuppress of a pattern was not recreating the slave parts
    PR 2112786: Motor direction is not reversing correctly in this model
    PR 6237593: Undo is not updating moved faces in a translated assembly
    PR 6242099: Failed PMI dimension appears to dramatically affect performance in this assembly
    PR 6248060: Relationships failing when replacing a subassembly using same base part
    PR 6274831: Menus defined in Environment Motion via Add-In prevent upgrade of add-in
    PR 1757437: Drawing Views are permanently out of date in the provided file
    PR 2134132: File load failure; list is copied incompletely
    PR 6097501: Groove welds/fillet welds fail when parts are inactive
    PR 6275140: Temp license for simulation gives X number of day’s left message regardless of duration
    PR 6281888: Getting simulation license expired message
    PR 1747503: Assembly Feature Performance degradation from ST to ST2
    PR 1763130: Adjustable part pattern does not behave the same as it did in V18
    PR 6262448: Get a display error message when transferring into an FOA file
    PR 6283906: Problems with assembly features failing on file open
    PR 2134733: Parts list is incorrect for an FOA member
    =====Draft=====
    PR 1751242: Drawing view could not be updated view after changing source from a weldment to assembly weldment
    PR 1752368: Improved performance issues with drawing view update
    PR 6275441: User data is lost when parts list is pasted
    PR 6281484: Parts list is missing when opened in ST2
    PR 6285477: Solid Edge crashed when entering text into combo box
    PR 1715016: Dimension values will not move, when DV is moved
    PR 6283924: Parts list failed after it was copied and changed to another model via edit links
    PR 1754125: Projection line breaks do not print
    PR 1760828: Difficult to locate broken out section profiles and problems with fitting drawing views
    PR 2130190: Added new automation for section view boundaries
    PR 6276308: Solid Edge is crashing during Save after placing a connector, then deleting
    PR 1684715: Showing hidden lines did not set drawing view out-of-date in some cases
    ===Mold Tooling===
    PR 1751932: Product aborts when opening, saving and closing a Mold Tooling subassembly
    ===API===
    PR 6266016: SEInstallData unable to return information
    PR 1767753: Contour flange is failing when bend table is called
    ===Insight/View & Markup===
    PR 6274801: Revise fails when “Who can view membership of the group” is set to members only
    PR 6262986: Cannot save PCF in Revision Manager, managed or unmanaged
    PR 1762264: A mixture of A4 Portrait and A4 Landscape stretches view in View & Markup
    PR 1766363: Wrong value for Revision Number is generated for implicit revised draft files
    PR 6284707: Cannot get full text index created
    PR 6287309: Assembly cannot be moved from Available to Released - Cannot Change Status
    PR 1767035: Assembly cannot be moved from Available to Obsolete - Cannot Change Status
    PR 6293898: Solid Edge fails to open file after selecting from Insight Dash Board
    PR 1766879: Revise will set an incorrect value for SharePoint column SERevisedFrom
    PR 6281407: Opening Revision Manager causes an Insight error
    =====Embedded Client=====
    PR 6279117: Uploading a file that is stored in Teamcenter allows the user to change the Item type
    PR 6279218: Solid Edge crashing after mapping date custom property to a text attribute
    PR 2135433: Certain user accounts can't create/save a draft file
    PR 6272925: Solid Edge Structure Editor crashes when selecting List of Values
    PR 1756631: Preference “SEEC_BOM_Synchronize” does not work with assemblies
    PR 6298313: The data prep analyze tool does not read the csv files correctly for foreign locales
    End
    Gianluca...alias Tequila
    41
    prog mec
    abruzzo
    solid edge
    sembra un lavoraccio
    ma è più stabile
    41
    prog mec
    abruzzo
    solid edge
    domandone?
    Ho istallato la 20 in ing
    posso aggiornare a st2?
    2874
    Veneto (PD)
    hanno corretto parecchi bug, ma ormai non faccio più tanto caso, ogni release nuova con i service pack correggono una montagna di bug e non solo in siemens ma anche la concorrenza...
    cosa intendi dire che hai la 20 in inglese e passare alla st2? Se sei in assistenza con il tuo rivenditore ed il tuo contratto è ok allora si puoi passare tranquillamente alla st2, se invece lo avevi disdetto e vuoi rientrare contatta il rivenditore della tua zona, se parli invece di copie del programma illegali qua hai sbagliato forum.
    Io in ufficio devo ancora installarla sul pc della mia postazione di lavoro, abbiamo 3 licenze e l'ho installata solo su quello di fianco che è libero per testarla. Lunedi aggiorno all' mp3 e poi la provo, comunque adesso valuto se installare la st2 anche sugli altri 2 pc o se aspettare l'mp4
    41
    prog mec
    abruzzo
    solid edge
    No no lic tutto ok
    lun mattina contatto il rivenditore
    ho visto un po di video in giro
    è na figata dall' asm poter manipolare i par
    41
    prog mec
    abruzzo
    solid edge
    ma il controllo con le forze meccaniche
    lo fa solo se generi l'assieme e poi lo leghi con le saldature o anche assemblandolo col metodo tradizionale?
    2764
    Citazione Originariamente Scritto da tauro rocco Visualizza Messaggio
    I contatti nell'analisi ( e più in generale in tutti i programmi FEM) vanno definiti dall'utente in automatico o manuale, specificando che tipo di legame c'è fra le facce.
    Non è necessario utilizzare il modulo di saldatura, dentro il modulo di analisi ci sono gli strumenti necessari.
    Cintura nera di solid edge
    41
    prog mec
    abruzzo
    solid edge
    grazie mille delle spiega raga!!!!!
    Mitici
    2874
    Veneto (PD)
    Predefinito ...
    ho installato la st2 con mp3, per ora gira senza aver riscontrato problemi ma devo ancora spremere a fondo il programma...
    546
    Ufficiale tecnico
    Solid Edge ST9
    "A regression was encountered with Solid Edge ST2 MP3 that was missed in the testing phase. Therefore MP3 has been removed from the download area. A new MP will be made available as soon as the regression is resolved.
    Based on our records you recently downloaded Solid Edge ST2 MP3. If you have not installed MP3, please remain on MP2 until such time a replacement is available. If you have installed MP3, it is recommended that you remove Solid Edge, re-install, and then apply MP2.
    We apologize for the inconvenience this may have caused you."
    Maledetta la mia fretta di avere l'ultima versione!!
