Risultati da 1 a 1 di 1
    4955
    Variabile
    AutoCAD 2016
    Predefinito Regolazione velocitÓ roll-up e roll-out tavolozze
    Palette Auto-hide Speed
    Did you know that you can change the time it takes to show/hide or roll-up/roll-out the palette windows in AutoCAD, AutoCAD Architecture or other verticals when you have activated Auto-hide? It is possible but is not so obvious and easy. Until now.
    Here you can download PaletteAutoHideSpeed.exe that helps you with this. There is no install provided since it's only one file so place it anywhere you want and run it. If you have different versions or verticals of AutoCAD you have to open the one you want to change and close it before running this application. (If there are problems to run it from a network location try to place it locally.)
    Hoover the mouse over "Tip here" in the application for a useful tip.
    For those wanting to know what the application does. Here's what. It locates the file fixedProfile.aws for the last run AutoCAD based application. It then changes the delay time in the file that is in XML format. In ADT 2006 it looks like this as default:
    < paletterollupdelay="600">< paletterolloutdelay="200">
    If you go in there and changes the Roll-up speed it will not work because of a minor spelling error. (Update: This has been corrected in ADT 2007) You also have to change PalleteRollupInfo to PaletteRollupInfo. The spelling error is corrected by the application.
    In AutoCAD there is no existence of these rows so they have to be added at the correct location.
    The “holdopen” delay is an additional delay that keeps the palette open for a specified time when it is opened programmatically; if the mouse does not move over it in this time it automatically rolls back up.
    <PaletteRollupInfo PaletteRollupDelay="600" PaletteHoldopenDelay="3000" />
    But is does not affect all palettes. You can see the effect with the palettes Properties, Quickcalc, External References, Sheet Set Manager, Markup Set Manager, Visual Styles Manager set to auto-hide. Try for example CTRL+1 one or two times. But it seems to only affect External References when starting AutoCAD.
    The requirement for the application to run is to have Microsoft .Net Framework v2.0 or later installed. It can be downloaded here. If you don't have it installed you will get a message when trying to start PaletteAutoHideSpeed.exe. We have no plan on supporting older versions of .Net Framework.
    Compatible with all existing AutoCAD based versions and verticals that uses palettes.
    http://www.jtbworld.com/PaletteAuto-hideSpeed.htm
    Ultima modifica di PlannerRoad; 30-09-2008 alle 17: 23
    1. Eliminare schede delle tavolozze
      Di jim78b nel forum AutoCAD
    2. Roll, pitch e yaw
      Di DeltaS4 nel forum Progettazione meccanica - forum generale
    3. Ordinare le voci nelle tavolozze
      Di lostico nel forum NX (Unigraphics)
    4. Condividere in rete le tavolozze
      Di papifra nel forum AutoCAD
    5. Regolazione luci nei render con revit
      Di GUGU nel forum Revit
