    RUGGIUNO
    Predefinito Solidworks 2009 Sneak Peak
    il 23 gennaio a san diego è stato presentato swx 2009
    - 4 volte più veloce e facile di swx 2008
    - miglioramenti per assemblaggi e routing
    - nuovi strumenti per lo schizzo
    - nuove funzionalità per le lamiere
    andate quì che c'è qualche notizia e qualche foto
    http://designsmarter.typepad.com/mik...orks-wo-3.html
    2098
    Bellissimo!!!
    Grazie del'info!
    dovresti passarla a quelli del forum!.Farebbe piacere...
    Saluti, Stefano.
    RUGGIUNO
    Bellissimo!!!
    Grazie del'info!
    l'ho spedita a Paolo Angeli
    RUGGIUNO
    Predefinito ANCORA SU SWX 2009
    E' IN INGLESE MA QUALCOSA SE CAPISCE
    DA QUI
    http://www.solidsmack.com/solidworks...ps/2008-01-28/
    Assemblies
    SpeedPak Technology
    I love the terminology they come up with sometimes. Speedpak does indeed sound better
    than amphetamine sulphate pak, but the results are the same. Adjusting a slider is like
    popping tabs as your model eliminates what components are loaded.
    Plus, you can make selections for what stays.
    I’m interested to know what/how it chooses to eliminate.
    I’m also kinda wondering if this is a modified, yet sexier, lightweight components.
    BOM in Assembly
    You can create a BOM in an assembly. When you edit a field in that BOM it updates
    the corresponding custom property. This looked great, but I’m concerned with large assembly BOMs.
    Will they be too small? Scalable? Multiple tabs?
    Toolbox Enhancements
    You can change configurations right on the screen and update bolt size using Instant3D.
    I cringe at toolbox stuff. Mostly because it’s never worked all that well for me and
    it lacks aircraft standard hardware. I’ll admit though, it’s been a couple years since I’ve used it last.
    It’s great they’re tying the Instant3D in with assembly
    Ribbon Cable Support
    There’s some added ribbon cable functionality added to routing. Looks like fun,
    but I don’t do wiring, so… ya, cool.
    Sketch Enhancements
    Dimensioning
    Dimensions suddenly appear as you’re sketching. As soon as you sketch a line,
    you can immediately type the dimension in. This is how it always should have been.
    I’m thinking (hoping) this will be an option because it could get annoying
    if you want to sketch or trace a quick profile.
    Slot Tool
    I don’t think I need to say anymore, except it works like the sketch offset tool,
    but fast as greased death.
    Negative Dimension
    Finally, some negativity. Enter a negative dimension, and it goes the other direction.
    Stretch
    With the tool you can stretch geometry that’s dimensioned. It supports negative dimension.
    Sheet Metal
    Solid to Sheet Metal
    This is more than just Insert Bends. Make a solid, select a main face and the edges to rip.
    It then wraps it in sheet metal and allows you to unbend it. There’s got to be limitation
    with complex parts which could be really annoying. Hopefully it will deal with these well.
    I can see this command eliminating a lot of typical problems with sheet metal
    and the process of step-by-step sheet metal feature creation.
    Plastic Tools
    Lip and Groove, Shell and Draft
    Automatically adds a lip and groove to the split part as well as Shell and Draft.
    They were going to quick to tell if this was in a single part file or if it could be done in an assembly.
    Seems simple in a part context.
    User Interface
    Command Manager
    I hear the angels singing with a lot of SolidWorks Users that like this thing.
    You can now put it on the sides.
    Double-Click Middle Mouse button Zoom-to-Fit
    Ya know, like in AutoCrad. They showed it in a drawing, so I’m not sure it’s the same in the model.
    If it’s not, it should be and for pete’s sake, zoom to the model geometry, not the boundary.
    Magnifier
    Quickly magnify an area of the screen without having to zoom in and out. Hmmm… Hmmmm.
    Sounds nice. You will have to see this because it made me kinda snicker.
    An actual magnifying glass pops up. I pictured an old coot with bad eyes.
    It’s neat I suppose, and watch, I’ll end up finding it the most useful thing.
    Triad Orientation
    Click on the X, Y or Z axis and the model is oriented to that view.
    A little bit closer to eliminating the view orientation toolbar and pop-up.
    Drawings
    Drag Drop Leaders
    You can drag and drop hole callouts to another instance of feature.
    Title Block Wizard
    Now you won’t have to edit the sheet format, use that crappy macro or hire someone
    to make a crappy macro for you. There are so many different types of title blocks out there;
    I’m really interested to see how this works.
    1. Solidworks 2009 e Ansys 12.1
      Di Protigy nel forum Ansys
    2. DWG EDITOR 2009 (solidworks)
      Di tormar nel forum Modelli 3D e risorse varie dedicate ai progettisti meccanici
    3. solidworks animator 2009
      Di NSPT nel forum Solidworks
    4. SOLIDWORKS 2009
      Di luca.c nel forum Solidworks
      Risposte: 45
    5. Solidworks 2009
      Di Gabriele SWX nel forum Solidworks
      Risposte: 158
