Risultati da 1 a 10 di 34
    Utente Standard L'avatar di checco03
    154
    Ingegnere
    I-deas - NX - SolidEdge- SolidWorks - Autocad - TeamCenter - Enovia V6
    Predefinito Controlli anti-pirateria
    Dear NX® Customer,
    Siemens PLM Software products constitute and contain valuable trade secrets and
    confidential information of Siemens PLM Software that have been developed over many
    years at considerable expense. We provide continuing improvement and customer
    assistance through our maintenance update service for correctly licensed users.
    We invest heavily in software development and enhancements in order to provide
    effective value and quality assurance to our customers.
    In recent years, Siemens PLM Software has seen an increasing amount of illegal use
    of our software in the marketplace, more commonly known as piracy. Piracy has a
    number of impacts including affecting the competitiveness of Siemens PLM Software
    customers who have legitimately licensed our software who have to compete against
    companies using unlicensed software. We share a common interest in stopping piracy
    as it affects both Siemens PLM Software and you.
    In order to protect both Siemens PLM Software's intellectual property and our mutual
    interests, Siemens PLM Software will embed an additional software security mechanism
    in our NX releases starting in February 2010 to monitor possible usage of unlicensed
    versions of NX. Such security mechanism may store data relating to the usage of NX
    and may communicate with computers controlled by Siemens PLM Software to report data
    relating to the usage of NX. If no unlicensed use is detected, no data will be
    communicated back to Siemens PLM Software. Furthermore, steps have been taken to avoid
    collecting any personal data.
    Siemens PLM Software is pleased to have you as an NX customer and we look forward
    to many more years of working together to our mutual benefit. Should you have any
    questions regarding this communication and/or your specific license rights, please
    contact your normal Siemens PLM Software Sales and Support office locally, who
    would be able to supply at your request a listing of the NX products our records
    indicate have been duly licensed by your company for reconciliation purposes.
    Best regards,
    Global Sales and Services
    1297
    non lo so più nemmeno io
    NX4-NX6-NX8
    guarda Checco,
    io non mastico molto l'inglese, ma da quanto ho capito , dopo la prima parte introduttiva di addolcimento ci viene detto che :
    da Febbraio 2010 verrà implementato un meccanismo di sicurezza che potrà immagazzinare dati sull'utilizzo di NX.
    Nessun dato verrà comunicato a Siemens se l'uso della licenza risultasse corretto.
    mi conferrmi che il succo è questo ?
    Rivenditore Stampanti 3D
    www.ipdesign.it
    9338
    Si piu' o meno dice quello che hai capito.
    A parte le questioni da "grande fratello" che effettivamente sono fastidiose, se usando questo sistema possono eliminare l'altro del 0x248 non sarebbe male.
    154
    Ingegnere
    Icon6
    guarda Checco,
    Esatto. Nel forum di Solid Edge ci sono delle discussioni aperte perchè anche lì è stato implementato un controllo simile: Solid Edge con licenza ufficiale esegue dei controlli random e, quando trova una parte eseguita con licenza pirata, la blocca. La mia opinione è che, in questo momento di crisi, questa strategia sia un modo per "raschiare la pentola" ovvero per vendere un po' di licenze a chi pensava di fare il furbo.
    9338
    Citazione Originariamente Scritto da checco03 Visualizza Messaggio
    Secondo me i sistemi di contrasto alla pirateria che funzionano servono anche agli utenti legali che si vedono cosi' sparire i concorrenti che fanno prezzi sottocosti per i ben noti motivi.
    Quello che non va e' il sistema di blocco dei file che scarica i costi e le inefficienze sugli utenti legali invece che sui pirati! Comunque questo sistema dovrebbe essere presente anche in Nx.
    154
    Ingegnere
    Scusa ma non guardo certe trasmissioni: potresti illuminarmi anche sul problema del 0x248 ?!?
    9338
    per "grande fratello" intendevo quello di Orwell (1984)!
    Il 0x248 e' il criptico errore che viene comunicato quando viene caricato un file illegale.
    1297
    NX4-NX6-NX8
    A me sembra un modo per far inc....re ancora più gli utenti onesti che la licenza l'anno pagata e qui si torna sempre alla stessa diatriba che ha innescato tempo fa polveroni.
    Ritengo che la maggiorparte delll'utenza regolare "voglia" ed abbia chiesto più volte a granvoce un controllo trasparente sui file provenienti da licenze "non conformi".
    Concordo con il sistema che "blocca" i file provenineti da tali fonti, ma credo sia più opportuno che tale blocco non avvenga "random" ma istantaneamente nel momento in cui viene aperto la prima volta.
    Mi spiego meglio :
    caso 1
    • sono un'azienda che affida un lavoro ad un progettista esterno
    • ricevo il materiale, lo apro e scopro che il file non è conforme
    • il file si blocca e non lo posso usare
    • non pago il fornitore
    caso 2
    • sono un progettista che per fare un lavoro mi appoggio ad un collega
    • ricevo il materiale ecc.. ecc...
    www.ipdesign.it
    9338
    Se sei vicino alla data di consegna del progetto, puoi anche non pagare il fornitore, ma poi sarai tu che arriverai tardi col tuo cliente, e magari oltre alla penale ci rimetterai anche il cliente, tutto per colpe non tue. Visto che alla siemens sono cosi' bravi, potrebbero direttamente mandare una scarica a 600 Volts sulle ws dove gira un soft piratato.
    Effettivamente il metodo del blocco dei file e' VERAMENTE un modo per guadagnare soldi con la bonifica di malware creato da loro stessi!
    1297
    NX4-NX6-NX8
    Scusate, mi è partito l'invia.. continuo
    un sistema random fa si che io cliente ricevo una bomba ad orologeria e con questo sistema l'invio di informazioni direttamente a Siemens fa sì che io committente possa essere intercettato come possessore di materiale piratato.
    Con le conseguenze del caso.
    Il blocco immediato invece mi mette in posizione di non poter utilizzare tale file, conseguenza che impone che prenda immediatamente provvedimenti con chi mi ha fornito tali file.
    Risultato = il rapporto cliente/fornitore sarebbe immediatamente trasparente
    riduzione di studi tecnici furbi che competono a prezzi irrisori
    è questo il punto finale della lotta , lavorare tutti con gli stessi parametri .
    concorrenza leale
    www.ipdesign.it
    1. Grigliato ed anti-biglia (normativa francese)
      Di mir nel forum Direttiva macchine (macchine nuove, macchine vecchie)
    2. Accordo anti-Pirateria
      Risposte: 29
    3. Controlli per rotazione 3D...
      Di zpaolo nel forum CAD meccanici a confronto
      Risposte: 16
    4. Controlli ASL nei cantieri edili
      Di gfrank nel forum Progettazione Architettura/Ingegneria edile
    5. Operazione anti pedofilia on-line
      Di arri nel forum Discussioni Off Topics
