    974
    Progettista/Disegnatore
    Roma
    Mechanical, Inventor, 3DS Max
    Predefinito Problemi con ASP.NET in Vista64...
    Inventor 2008 su Vista64.
    Ho un "grave" problema con ADMS: in poche parole si è incasinato e, di conseguenza, le librerie ed il Vault non sono disponibili.
    L'utility di controllo di ADMS non segnala alcun errore, ma l'Event Viewer mi segnala:
    Could not load file or assembly 'Connectivity.EDMWS.AppDomain, Version=12.1.145.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. Access is denied. at System.Reflection.Assembly.nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection)
    at System.Reflection.Assembly.InternalLoad(AssemblyNa me assemblyRef, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection)
    at System.Reflection.Assembly.InternalLoad(String assemblyString, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection)
    at System.Reflection.Assembly.Load(String assemblyString)
    at System.UnitySerializationHolder.GetRealObject(Stre amingContext context)
    at System.Web.Hosting.HostingEnvironment.CreateInstan ce(Type type)
    at System.Web.Hosting.ApplicationManager.CreateInstan ceInNewWorkerAppDomain(Type type, String appId, VirtualPath virtualPath, String physicalPath)
    at System.Web.Hosting.ApplicationHost.CreateApplicati onHost(Type hostType, String virtualDir, String physicalDir)
    at Connectivity.EDMWS.AppDomain.WebApplication.Intern alProcessRequest(RealRequest realrequest)
    at Connectivity.EDMWS.AppDomain.WebApplication.Proces sRequest(RealRequest realrequest)
    at Connectivity.EDMWS.AppDomain.RealRequest.Process()
    at Connectivity.EDMWS.AppDomain.Server.OnSocketAccept (Object acceptedSocket)
    Ovviamente ho provato a reinstallare/riparare, ma non riesco a portare a termine la procedura perchè, per alcuni file, non ci sono i diritti necessari e viene restituito "error 1321: The Installer has insufficient privileges to modify this file"
    Ho provato ad impostare l'account System sulla cartella (e sottocartelle) "C:\Program Files (x86)\Autodesk\Data Management Server 2008\Server\Web\" ma senza risultato (fra l'altro la cartella VaultHTML è assolutamente inacessibile).
    Naturalmente uso l'account di tipo Administrator (anche l'account Administrator vero e proprio) senza UAC.
    Niente da fare...
    Qualcuno mi dice come sono impostati i privilegi sulle cartelle \Web?
    O eventualmente come disinstallare "brutalmente" ADMS?
    PS: usa Vista da mesi e mi trovo benissimo... il problemo credo sia nato quando (ma non ne sono assolutamente sicuro) ho installato il VaultAutoloader e DWG TrueView 2008)... inutile suggerirmi di tornare ad XP ;)
    1674
    piemonte/lombardia
    TOGLI INVENTOR E IN SNSTALLAZIONE APPLICAZIONI TOGLI ANCHE CIò CHE RIGUARDA SQL SERVER...
    REINSTALLA, METTI SP2
    V
    974
    Roma
    THX... appena ho più tempo proverò qualcosa di più "radicale" come hai suggerito... sperando che funzioni...
    Devo solo capire quali sono le istanze di SQL da disinstallare... in Vista l'elenco delle applicazioni è diverso da quello che mi ricordo di XP (per capirci, non c'è l'istanza SQL Autodesk).
    1674
    piemonte/lombardia
    microsoft sql
    tutte
    a meno che non haiinstallato altri software che lo usano...
    stiamo parlando di 2008 vero?
    v
    974
    Roma
    microsoft sql
    Sì, Suite 2008 (Sp2)...
    1. problemi con dll
      Di rita ga nel forum 3D studio
    2. PROBLEMI CON LA RAM E PRO-E WF4
      Di DANI-3D nel forum Creo Parametric (ex Pro/E)
    3. Problemi con la V20
      Di AlexOnWeb nel forum Solid Edge
    4. Problemi con dxf
    5. Problemi??
      Di Whooring nel forum Solidworks
