    2874
    teorico del paleocontatto
    Veneto (PD)
    Predefinito update solid edge STv100 mp11
    è disponibile il download del MP11 per solid edge STv100
    Gianluca...alias Tequila
    1233
    Veneto - Emilia
    Queste le novità:
    Legal Notices
    ©2009 Siemens Product Lifecycle Management Software Inc.
    All Rights Reserved
    Software, file formats, and audiovisual displays may be used pursuant to the
    applicable Software License Agreement and contain confidential and proprietary
    information of Siemens Product Lifecycle Management Software Inc.; which is
    protected by copyright and trade secret law. Such materials may not be reproduced
    or transferred to other documents or used or disclosed to others for manufacturing
    or for any other purpose except as specifically authorized within the terms of the
    Software License Agreement, or as specifically authorized in writing by Siemens
    5800 Granite Parkway
    Suite 600
    Plano, TX. 75024
    End of Legal Notices
    Release Notes:
    Product: Solid Edge
    Version: 100.00.11.03
    Date: 14-Oct-2009
    This Maintenance Pack can be installed on top of Versions:
    100.00.00.133, 100.00.01.07, 100.00.02.07, 100.00.03.03, 100.00.04.04,
    100.00.05.04, 100.00.06.03, 100.00.07.04, 100.00.08.03, 100.00.09.04,
    100.00.10.05
    Note: Maintenance Packs are all inclusive and can be installed on top of the base
    release or any released Maintenance Pack.
    End of Release Notes
    Installation Notes:
    After downloading the Maintenance Pack to your machine, dbl click the downloaded
    file and the Maintenance Pack will install.
    End of Installation
    This Maintenance Pack addresses the following PRs:
    =====Assembly=====
    PR 1588004: Ghost lines are visible in assembly
    PR 1742690: User cannot locate keypoints when placing a circular pattern
    PR 2110613: Segments of XpresRoute become disconnected in this file
    PR 6135731: Cannot locate part geometry for measurement in this file
    PR 6183872: Fixed a crashlog abort
    PR 1724903: Hole cannot be edited because of missing profile and extent type parent
    PR 1685486: Replacement of a family member causes relationships to fail
    PR 1750159: Crash when selecting parts within a group
    PR 5949185: Assembly cutout sketch and plane not moving as part is moved
    PR 6126503: Predefined archive entities were not getting copied into the active model session
    =====Part/Profile/Sheet Metal=====
    PR 1746654: Cannot unfold in ST
    PR 1747721: Problem saving sheet metal part as ACIS file
    =====Draft=====
    PR 1741615: Bogus error messages when removing item count from multiple balloons
    PR 2130060: Wrong angular dimensions
    PR 6229940: Solid Edge Draft aborts when using the Trim command on background sheet
    PR 6229622: Printing (or saving as PDF) shaded views is not working correctly with ST MP10
    PR 1734926: Incorrect text display in viewer data
    PR 1741621: Draft file is not saving when performing a special workflow
    PR 6225522: Not getting a title block when exporting to DXF on 64 bit machine
    ===API===
    PR 2130405: Trouble occurs when "Addin" is registered in "Quick Access Toolbar"
    PR 6216674: MoldTool command images incorrect
    PR 2129831: In SynchronousParts, "CopySurface.Type Property" cannot be acquired
    PR 2129884: Implemented InterpartConstructions and InterpartConstruction automation methods
    PR 6222930: Automation on model node: cut length and component name
    ===Insight/View & Markup===
    PR 1747128: Insight managed files cannot be converted to synchronous
    PR 6228351: Multi-national clients can't sync to English server
    =====Embedded Client=====
    PR 1703717: Having problems changing the separator for Solid Edge dataset names
    PR 6221906: BOM mismatch due to ordered list being incorrect
    PR 6224180: Error on draft check-in after IPA and check in of assembly from draft view
    End
    Ciao e Buon Lavoro........
    1. Risposte: 36
    2. Risposte: 8
    3. Solid EDGE STv100 informazioni utili
      Di Tequila nel forum Solid Edge
      Risposte: 20
    4. Risposte: 2
