    974
    Progettista/Disegnatore
    Roma
    Mechanical, Inventor, 3DS Max
    Predefinito Autocad Mechanical 2010
    Autocad Mechanical 2010 - What's new
    What’s New
    Constraint Manager - Using the constraint manager, users can easily build intelligence into their designs by incorporating dynamic constraint relationships such as parallel, tangent, and perpendicular.
    Symbols - AutoCAD Mechanical 2010 supports welding and surface texture symbols, as well as libraries for dead joint, edge, and feature control frame symbols.
    AMSETUPDWG - You can now import selected standards, surface texture preset lists, note templates, and symbol libraries.
    Intelligent Drafting Features: With even more intelligent drafting features for automating common design tasks, AutoCAD Mechanical 2010 offers significant productivity gains and can help save countless hours of design time.
    Streamlined Design Environment: AutoCAD Mechanical 2010 software features a streamlined user interface. Find favorite tools and commands faster, locate less frequently used tools more efficiently, and discover relevant new features more easily.
    Bills of Material: Enhancements to AutoCAD Mechanical 2010 help users create accurate bills of material (BOMs) and parts lists even faster. Save time and maintain accurate information by automatically extracting BOM data from existing DWG files.
    Part Publishing: Users not only have access to the more than 750,000 standard parts and features included with AutoCAD Mechanical, but also can now easily get the full value from their existing part designs. Part publishing offers the capability to add new part families to the library, helping save time and maintain consistency across projects.
    AutoCAD Mechanical 2010 Bills of Material Extraction:
    A feature unique to AutoCAD Mechanical 2010, users can save time and maintain accurate information by automatically extracting BOM data from existing DWG files.
    AutoCAD Mechanical 2010 Part Publishing Content Library:
    Ultima modifica di GiGa; 11-03-2009 alle 16: 25
    974
    Roma
    ... non ho ancora capito se hanno implementato la possibiità di registrare le macro, come in Autocad "base"...
    Inoltre, i vincoli sono la novità della serie 2010, ma il "Constrain Manager"... che sia solo per Mechanical?
    1. AutoCAD Mechanical 2010 e Tecnometal
      Di Nada84 nel forum Autocad Mechanical
    2. Subscription Advantage Pack per AutoCAD Mechanical 2010
      Di GiGa nel forum Autocad Mechanical
    3. Versione Italiana autocad Mechanical 2010
      Di MISTERPRIMUS nel forum Autocad Mechanical
    4. AutoCAD Mechanical 2010 Update 1
    5. AutoCAD Mechanical 2010: mancano icone due comandi
      Di vale79 nel forum Autocad Mechanical
